replacement Battery Cables Recommendations?
Old Mar 6, 2006 | 04:54 PM
burley208's Avatar
burley208
I need new battery cables for a 94 f250 IDI with dual bat set up that is stock. any recommendations?
Old Mar 6, 2006 | 06:07 PM
Hamberger's Avatar
Hamberger
Stock cables from Ford are expensive (especially the +ve cable that picks up both batteries.)
I ended up getting a 1 gauge cable for my passenger side battery on my 91' F350 from the local autoparts store which I ran directly to the starter. The new cable came complete with battery connector and loop to the starter motor for about $20. I was able to save the rest of the existing +ve cable from the drivers side battery by sawing off the +ve connection loop for the existing passenger side battery and taping it up. This takes have the load of the existing cable.
You should be able to buy 0 or 1 gauge -ve cables at most autoparts stores.
If you need to replace the long +ve from the drivers side battery to the starter you either do a custom job or bite the bullett and pay for it thru Ford. I am not aware of anybody that makes an aftermarket cable specifically for these trucks.
Whatever you do use heavy gauge cables (0 gauge) or welding cables.
Old Mar 6, 2006 | 06:35 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The stock cable is way bigger than #1 or #0.
The crossover from the drivers side to the passenger side is 2/0 AWG.
The wire from the passenger side down to the starter is 3/0 AWG.
I had a cable made out of 2/0 with crimp on ends made at NAPA to go from the drivers side battery to the starter for about 30 dollars. 7 feet long if I remember right.
Then they made another to go from the drivers side battery to the starter that was about 25 dollars.
Sure was better than the 225 Ford wanted.
Old Mar 6, 2006 | 07:42 PM
Heatnbeat's Avatar
Heatnbeat
I made cables with flat, bolt on style crimp ends. For terminal connections I used the ones that have a bolt in the end and are used to connect top terminal batteries to side terminal cables. The crimp ends bolt onto the end of the terminal quite tightly. So far it seems to be a good working and inexpensive soloution.
Old Mar 6, 2006 | 08:30 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
take the original cable to most semi truck dealerships and they can make you a set really reasonable.
Old Mar 6, 2006 | 09:30 PM
94_turbo's Avatar
94_turbo
someone over on tds also said you get get the cable from interstate battery for very resonable--
Old Mar 7, 2006 | 12:41 AM
Taters's Avatar
Taters
I replaced mine last summer. After checking witn Napa and Ford OEM, I ordered cables from custombatterycables.com. I got the set of three cables for about $100. The quality was great and they fit perfectly. I'd definitely recommend them.
Old Nov 5, 2006 | 05:32 PM
chrisjrosenbohm's Avatar
chrisjrosenbohm
http://www.custombatterycables.com/contact_info.htm
cheapest i found super quality too
jomoflymo
Oct 3, 2014 11:57 AM
banjopicker66
Oct 26, 2009 08:06 PM
livinezy
1983 - 2012 Ranger & B-Series
Feb 6, 2008 11:00 AM
newstroker
Nov 30, 2007 06:26 PM
gokart2
Modular V10 (6.8l)
Oct 1, 2007 05:04 PM
