Sponsored by: Real Truck
Overdrive light flashing??? . . .
Old Mar 6, 2006 | 01:05 PM
live2hunt's Avatar
live2hunt
Something new and very strange has happened a couple times the past two weeks.
I would start the truck, and when I started off, the truck would sputter and feels like it would die if I hadn't put it in neutral and gently reved it a couple times. Then it would opperate normally. The second time it happened, I also noticed the overdrive light was flashing on & off. I had not engaged it or touched it. It is an F350, 2001, 7.3L FPS, 70K miles. Both days were cold, below freezing cold. And both times it would run fine after reving it in neutral for a little bit. And it would run fine the rest of the day.
What the h*#! is happening?
Old Mar 6, 2006 | 01:46 PM
wlihntr's Avatar
wlihntr
the OD light flashing is the SES light for the transmission. take it to one of the larger autoparts stores and have them scan it for. you probably have some codes stored
Old Mar 6, 2006 | 01:49 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Could be the VSS (speed sensor) on the top of the rear-end housing.
Does the speedo jump when this happenes?
The bad news is it could be a tranny problem. The flashing O/D light means the computer saw a problem with the tranny. The most common cause of this is the speed sensor is going and the computer sees the tranny turning but not the rear end. So it flashes the light.
The easy way to tell is if the speedometer stops or jumps around when this happens.
If the sensor doesn't fix it, I'd bring it to a tranny shop for a diagnostic. The computer can store a code for the tranny if the O/D light was blinking, that would tell more about what the problem is.
Old Mar 6, 2006 | 06:04 PM
kpd73's Avatar
kpd73
My truck did the same thing it was the speed sensor in the rear end. My o/d light flashed and my speedo would not work. I took it to the tranny shop to have the computer scanned, they did it for free, turned out to be the speed sensor. Ford was the only place I found that had the sensor about $25 (they had about 20 in stock) this is a very coommon problem according to the parts salesman.
Old Mar 6, 2006 | 10:45 PM
live2hunt's Avatar
live2hunt
Thanks all . . . but what about the sputtering? And is it related?
Old Mar 7, 2006 | 09:06 AM
krewat's Avatar
krewat
Was it sputtering or was it that the tranny couldn't make up it's mind?
Get the thing read for codes, if you have any doubts. That'll tell you what's up.
Old Mar 7, 2006 | 07:26 PM
wolfbike1500's Avatar
wolfbike1500
My truck did it and it was the Mass Air Flow Sensor. Evidently it talks to the tranny about shift timing and such.
99 F350 Lariat V-10 4x4 CC LB SRW
Old Mar 7, 2006 | 09:47 PM
krewat's Avatar
krewat
It flashed the O/D light because of the MAF?
Old Mar 8, 2006 | 06:09 AM
wolfbike1500
Yes it did! I disconnected the battery to stop the flashing light but it kept coming back. I put a code reader on it and it said I had a "pending failure" of the MAF. I sprayed it with electronic cleaner and the problem has not come back.
Old Mar 8, 2006 | 07:55 AM
krewat's Avatar
krewat
that's an interesting nugget of info... thanks!
Old Mar 8, 2006 | 08:27 AM
Dsl Lover's Avatar
Dsl Lover
I had the OD Flashing issue when I got stuck (With the 29' TT in tow). After 1/2 hour of trying to get unstuck, the OD light was blinking like mad. It was winter, and there wasn't anyone else in the campground until a Ranger finally came and helped me out.
In my case, the flashing indicated that the transmission was over temperature. I dropped it into park (Diesels and maybe all SD's still circulate the tranny fluid in park) and raised the RPM's for 10 minutes or so and the light shut off...Never to return (I never tried to shift back and forth so many times again - also I bought much more aggressive tires). I doubt that applies to you as your tranny was cold.
Old Mar 8, 2006 | 09:36 AM
krewat's Avatar
krewat
Unless the temp sensor is bad
Gotta get the codes read. Period.
Old Mar 8, 2006 | 11:06 AM
Dsl Lover's Avatar
Dsl Lover
No, I'm positive that the tranny was hot - Shifting forward to reverse, to forward to reverse for a half hour trying to rock loose an 8000lb trailer for a solid half hour + ? It was hot - no question. So was I, lol. But thanks for the tip.
Old Mar 8, 2006 | 01:10 PM
krewat's Avatar
krewat
You got me wrong...
I meant the other guy's tranny As in, if the temp sensor is bad, the computer might see "hot" instead of "cold"...
Again, gotta get the codes read.
