"Idiot Gauges"
Old Mar 8, 2006 | 12:36 AM
Col Flashman's Avatar
Col Flashman
Yogi-96blazer
As when the truck is running & then the "Idiot Light/s" go on.
Yes they will always come on when you first start the truck up, as it lets you know the Lights are working & not burned out.
The "Alt." Flickering or Staying on @ low R's means that it Not making enough current & the "Idiot Light" is letting you know that.
The "Oil Presure Idiot Light" will come on when it senses Low (flicking light) or No Oil (steady light) being Sensed in the system.
In other words, something is wrong, you need to put a quart or 2 in the engine (chequing how much is needed is a good thing) as in your either burning it or you've a gaskit leak or you've bashed in you Oil Pan & are in real big trouble or you've blockage in the oil pump, screen, galleries or your oil pump is going bad (flickering) or just died (steady). Though, that's just been my experience.
Old Mar 8, 2006 | 07:11 AM
Yogi-96blazer's Avatar
Yogi-96blazer
Originally Posted by Col Flashman
Yogi-96blazer
Oh alright thanks. Well i might not have a good conection the positive lead to the batt is just sitting there not tighted down cause i been taking it off and on alot doing things to the truck.
thanks for the info.
dmp
Michigan Chapter
74
Jun 25, 2015 02:31 PM
jazzygreen
13
Jul 8, 2013 11:41 PM
megawatt00
52
Sep 25, 2012 06:01 PM
BLADE35
Jun 4, 2011 02:25 PM
stu37d
Dec 7, 2006 09:24 PM
