I have been told that it is not possible, but, I would like to raise the front of my truck up about two inches. I have a 1978 F-250 Supercab Camper Special 4x2. The front springs are coil and the only idea I have is to have a pair od custom springs made.
The main reason I want it listed is to even the truck out, the back end sticks up quite high, and looks funny to me.
The other reason is that the tires that I have are rubbing slightly on the fenders.
If it is IBeam suspension you have to have your I beams bent or have new ones made. You could also drop your Ibeam pivot points and just get lifted coil springs.
