Sponsored by: Kumho
bleeding brakes???
Old Feb 8, 2006 | 11:08 PM
Jack-USAF's Avatar
Jack-USAF
bleeding brakes???
1988 F-150 4x4 5.0. I was trying to bleed my brakes this past weekend and I started in the rear and absolutely no fluid came out. But the front brakes squirt all day long. And there is/was plenty of fluid in the reservoir. I followed the lines and had no leaks, cracks, kinks..... I had my buddy in the cab pushing the pedal for me. Can anyone help me out on why I am not getting fluid to the rear brakes? Thanks.
Old Feb 9, 2006 | 03:56 AM
stuart1's Avatar
stuart1
Old Feb 9, 2006 | 03:57 AM
stuart1's Avatar
stuart1
You need to do this.
Old Feb 9, 2006 | 11:39 PM
Jack-USAF's Avatar
Jack-USAF
stuart1, i have no idea what that is.
Old Feb 10, 2006 | 05:42 AM
stuart1's Avatar
stuart1
That is in the proportioning valve.
The small pin must be pulled out and held while the brakes are bled then released.
If you have a 350 the pin must be pushed in.
Old Feb 10, 2006 | 07:36 AM
teds74ford's Avatar
teds74ford
Interestingly, I didn't do that to mine, and bled an entire new system, except for the valve, with a suction bleeder. It was a good bleed too. Maybe it is because the suction isn't compressing air.
Old Feb 10, 2006 | 11:10 AM
Jack-USAF's Avatar
Jack-USAF
I will mess with it again this weekend. Where is the proportioning valve located?
Old Feb 11, 2006 | 07:11 AM
teds74ford's Avatar
teds74ford
I think on a newer truck like yours it is right under the master cylinder. On mine it was mounted to the frame below the master cylinder. Follow the lines from the master cylinder and they will go to it.
Old Feb 11, 2006 | 12:49 PM
nebechanezer's Avatar
nebechanezer
where do you get that little tool for holding it out?
Old Feb 11, 2006 | 02:24 PM
stuart1's Avatar
stuart1
It doesn't take much to hold it out.
I use a small kelly clamp.
Old Feb 11, 2006 | 04:08 PM
nebechanezer
whats a kelly clamp. i've never heard of that.
Old Feb 11, 2006 | 07:11 PM
stuart1's Avatar
stuart1
They are used in the OR. You can get one at a drug store.
Old Feb 11, 2006 | 09:06 PM
nebechanezer
guess i shoulda asked my wife, who'da thunk.
Old Mar 6, 2006 | 06:03 PM
Nathane's Avatar
Nathane
how far do u need to pull that pin out when bleeding?
tks alot,
~Nate
Old Mar 6, 2006 | 08:04 PM
stuart1's Avatar
stuart1
It only moves a short distance, so all the way and hold it there.
