yes, that is a cooling fan inside. Unless you run it continous for as long as you can, or give it poor power supply, it will do fine, as it is designed to weld. It only over heats if you keep on it constantly for over 5 minutes at a time. It is rated 20% duty cycle, which means that it can run 20 minutes of an hour.
Duty cycle is based on a ten minute time period. So a 20% duty cycle means you can weld continuos for 2 minutes at the MAXIMUM rated amperage. Decreasing the amperage extends the duty cycle. See Duty Cycle
Okay sorry you didn't get it. I checked it again and it still works okay for me. Here's the quote from the Welding Dictionary I linked to:
Originally Posted by millerweldsdotcom
Duty Cycle - The number of minutes out of a 10-minute time period an arc welding machine can be operated at maximum rated output. An example would be 60% duty cycle at 300 amps. This would mean that at 300 amps the welding machine can be used for 6 minutes and then must be allowed to cool with the fan motor running for 4 minutes.
Miller Electric has a lot of good articles and information. Check their website millerweldsdotcom and point at 'Education' on menu, then chose 'Welding Library.'
