6v alt.
Old Mar 5, 2006 | 10:55 PM
Jon Henry's Avatar
Jon Henry
Question 6v alt.
If I replace the 6v gen. with a 6v alt., are there other changes needed to keep everything original? '36 FH, 85 HP. That would give me brighter lites at idle and keep the batt. charged, right?~Tks
Old Mar 6, 2006 | 12:07 PM
Franklin2's Avatar
Franklin2
I do not know anything about the 6v alternators and if they improve anything or not. One thing I have heard that improves an old 6 volt system is changing the battery to an 8 volt, and adjusting the old 6 volt generator regulator to charge the 8 volt battery. I have heard of people doing this and being much happier with their cranking speed and the brighter lighting.
It sounds simple enough. Buy an 8 volt battery, and get a local automotive electrical shop to adjust your regulator to charge an 8 volt battery properly.
Old Mar 7, 2006 | 02:25 PM
alienbaby17's Avatar
alienbaby17
Try to find 5th Avenue Auto. Electric online. They specialize in 6 volt alternators. Also the guy LITERALLY wrote the book on the subject. Check him out.
Old Mar 11, 2006 | 02:00 AM
midlf's Avatar
midlf
try this link
http://www.fifthaveinternetgarage.com/
Old Mar 11, 2006 | 10:30 PM
jimdandy's Avatar
jimdandy
I don't know that you would be helping yourself any. 6 volts is 6 volts no matter where it comes from. Charging limit is around 7.3 volts in a 6 volt system. For that reason, I don't think I would tinker with going to 8 volts. jim d
Old Mar 12, 2006 | 06:20 AM
Franklin2's Avatar
Franklin2
Just like a 12 volt alternator can be turned up to put out 120 volts,(or turned down to produce 6 volts),a generator can be turned up too. It's all in the regulator and the speed it's turning. A little tweaking in the regulator by a automotive electric shop should bring it right on up. I would guess it would need to be somewhere around 9 or 10 volts, I am not sure on that one.
Old Mar 12, 2006 | 10:59 AM
jimdandy's Avatar
jimdandy
This is true, but you are increasing voltages by 1/3. While this may not seem like much in a low voltage system, it is a lot. Devices that operate at 6 volts have built in overload, but are not really designed to operate at higher voltages for long periods of time. That is why the 6 volt system charging circuit is limited to around 7.5 volts.
6 volt systems work fine, but they must be maintained like everything else. Clean connections, pay special attention to grounds, and keep the engine in tune.
In my opinion, if you are going to increase voltage, go ahead and go 12 volts then you don't have an odd voltage to deal with. I re-wire old cars as a hobby and this is the system I use. jim d
Old Mar 12, 2006 | 11:46 AM
Jon Henry's Avatar
Jon Henry
Talking upgrade
Hey Jim; Can I pick your brain alittle? A 12v gen. will still drain the batt. on short hops, right? There's an outfit in Ohio that makes 6 & 12v alt. for FH's with the mounting brkt and pulley. Have you had any experience with them? I'd have to re-mount the fan blade on the new pulley or spend more for an elec.fan, not cool.
If I can get a new 12v alt. setup that works, I'd only need one or two runtz's, right? Right now I've got a vintage Firestone 6v heater that I'd like to install. Someone told me a runtz won't work for heaters, what is used?
I'd better let you go for now. Later~Dan~
Old Mar 12, 2006 | 12:52 PM
Franklin2's Avatar
Franklin2
I agree completely with that.
Dan, I get the impression from the above statement you are fretting and worrying over something that hasn't even happened yet. Hopefully Jim will write back and confirm again his statement above, and convince you that you do not need to pour a lot of money into some fancy 6v alternator and such to get good enough performance from your original 6v system. The heater and few accessories you are adding are not going to hurt the 6v electrical system in your truck, no matter what kind of driving you do.
Many short trips will affect exhaust and engine life more than anything else.
Old Mar 12, 2006 | 02:41 PM
Jon Henry's Avatar
Jon Henry
Talking 6v
Hey Dave; You are right-I'm probably worrying too much about a simple fix! My readings of upgrade articles seem to say that it's the gen. that doesn't run long enuf to re-charge the batt., but an alt. will. I rarely go more than 10 mi. a pop so it seems that the alt. is the answer. Believe me, I don't want to spend $200+ if I don't have to!! Thanks for your input. ~Dan~
Old Mar 13, 2006 | 12:35 PM
jimdandy's Avatar
jimdandy
If it were mine, I wouldn't mess with it. 10 miles is sufficient to keep the battery charged. An alternator charges at idle or near idle due to the smaller pulley. If the vehicle sits for long periods, a trickle charger would be my solution. jim d
D2W
Ontario Chapter
Jul 14, 2013 11:07 AM
Joe in Austin
Nov 18, 2012 10:58 AM
Pitcrw6
Aug 26, 2012 12:59 PM
Grubbworm
Apr 21, 2011 09:56 PM
Grubbworm
Apr 21, 2011 12:35 PM
