2004 Explorer ATF flush
Old Mar 4, 2006 | 10:29 PM
Chinookman's Avatar
Chinookman
Well just how does a shade tree guy go about draining and replacing the ATF on these machines w/o a fill tube dip stick?
It's got 28k and I just don't like going the 36k duration w/ ATF.
It's had the OEM FoMoCo ATF additive done by dealer but the shifting still SUCKS!!!! Of course I'm in it too deep to trade and can't convince my 5'3" wife she needs a Titan.. so I'm stuck and want to go w/ synthetic ATF.
Appreciate the help guys....C-man
Old Mar 5, 2006 | 09:52 AM
Joe B's Avatar
Joe B
You need the tool nut here or a home made thigamagig.
I also used a 4gallon pump system vs the hand pump.
Dropped the pan.
Installed a new filter.
Had to pump out and fill through that tool nut on the pan.
Purged out much of the old fluid through the cooler line into a 5 gal bucket and adding Amsoil with engine running.
Went though 18 qts of Amsoil ATF with trans and transfer case.
Can't check the fluid with a dip stick so I had to watch for fluid return drip out of the fill hole after removing pump line through that fill tool nut.Dripping shows the trans is full.
All in all pretty much of a pain in the *** without a dipstick..
Changed the fluid in transfer case,trans filter,gas filter along with the front and rear diff fluid to Amsoil Severe diff oil.
Next year I'll flush the brake lines,PS pump and drop the trans oil in the pan,add 6 or so qts of Amsoil to get a higher percentage than I have now.
Overkill?
Maybe but I'm a pre-maintence junkie.
Old Mar 5, 2006 | 09:27 PM
Chinookman's Avatar
Chinookman
Thanks Joe, I'll crawl down underneath and take a look at what you refer to as the tool nut. So I gather that the 'return' line get removed in this process?
Oh well thanks and you can count on me requesting mo' help in about two weeks when I get to this. Gottah git Bob Reilly to send me mo' Amsoil ATF and have the HX mod on my Stroke to do 1st, oh yeah and the coolant filter install....he-he don't ever stop but everyone needs a hobby.......he-he-he.....C-man
Old Mar 6, 2006 | 05:34 AM
Joe B's Avatar
Joe B
Here's the link I forgot to post on that special fill nut and some instructions on filling. .
http://autorepair.about.com/library/faqs/bl066i.htm
rb8612
Jun 4, 2011 06:00 PM
eric777
17
Aug 26, 2006 06:54 AM
Pass The Peas
Oil & Lubrication
19
Aug 10, 2004 02:10 PM
BigMattXXL
Oil & Lubrication
18
Dec 2, 2002 09:48 PM
