What are some of the older types of drywall? Because I have some drywall on my celing that has paper to it. But it peels and has the drwall under it. Thanks!
oh, and you may have found some seaming taps, which is used over two pieces of sheetrock, but your question is a little lacking in the details, if you have any more, I may be able to help you more.
I always called water restaint sheetrock, greenboard;
and Wonderboard for the cement backer board.
I know we're required to have a minimum of 5/8" rock on both sides of any wall that is either on the exterior walls or on any wall seperating the living space from a garage.
I have an old house, and I'm always changing or remodeling something.
In a room upstairs, someone had used sheetrock that had paper glued to it. The paper was printed to resemble wood paneling. It also had the paper that you normally see on drywall.
I had a tornado hit my house in '98 and blew out the upstairs windows and that drywall got wet. The 'veneer' puckered but the regular paper stayed bonded.
I've removed all that old stuff but, if I remember correctly, it was produced by U.S. Gypsum and was dated in the early '60's.
I don't know if what you have could be fixed or not but, my solution was to replace it.
After plaster, they went with a sheetrock that was something like 2'x4'. A bad seam job really stuck out on them, but there were a lot of plasterers around at the time that could hide seams well. I still see some of that around, it's paper covered. Sounds like someone might have wallpapered the ceiling, during the fax wood paneling 50's and 60's era.
One of the rental houses I'm currently gutting has this 2'x4' drywall. The stuff is pretty thick, about 3/4". Best we can tell it was put on in the mid to late 50's. All inside corners use a metal lathe instead of tape. Then all walls were skim coated with plaster. Needless to say, it makes a dirty job that much worse. Hauled out a truck load so far. About 6,000 pounds worth at the dump. Definately better then today's drywall jobs. Extremely well done, 50 years of worth of renters and still looked very nice. Hated to tear it out, but we're converting the house back to a single family.
