94 Ranger Check Engine Light
Old Mar 4, 2006 | 06:42 PM
bnewkirk's Avatar
bnewkirk
The check engine light on my 94 Ranger with the 4.0 engine came on a day or two ago has has not gone off. Since it is a 94 I am assuming it does not have an ODB-II check point for a scanner. Is there another way to get the code that has tripped the CEL?
Thanks
Bob In Indy
Old Mar 4, 2006 | 07:54 PM
AlfredB1979's Avatar
AlfredB1979
Yes.
Find a paper clip or ANALOG voltmeter, get your Haynes manual out--turn to Chapter 6, I believe, and read needle sweeps from the voltmeter or the actual check engine light flashes. Then consult Haynes manual for the code numbers and come back to us if you need help deciphering the codes you find.
Or someone may link you to a thread on checking codes, if we have one.
Old Mar 4, 2006 | 09:56 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
The details on how to pull codes from your EEC-IV system are in the tech info sticky at the top of this forum.
Old Jul 11, 2008 | 10:27 AM
spenmax's Avatar
spenmax
need help on location of crank sensor before i go spend 118.00 bucs, my check engine light is on for a while now and notice a strong odor from exhaust when backing up in garage. Ive replaced egr,wires,plugs,02 sens,been told to replace crank sensor or ign. mod. both over 100.00 bucs, need advise...
gwuister
May 5, 2011 03:21 PM
PurerockRacing
Jan 18, 2011 09:29 AM
Lou58
Jan 14, 2011 08:40 PM
frdkid88
Mar 8, 2008 11:25 AM
03f2506.0
Jul 29, 2006 08:08 AM
