obd II
Old Mar 7, 2008 | 08:51 PM
frdkid88's Avatar
frdkid88
obd II
Does a 94 ranger with a 4.0 use a obd II for the check engine light. If so where is it located. Its my truck at work and it throws a CEL once and a while and i wasnt sure if it used some other system.
Old Mar 7, 2008 | 10:18 PM
yompe's Avatar
yompe
94 model is ob1 ob2 started in 96
Old Mar 7, 2008 | 10:46 PM
Rockledge's Avatar
Rockledge
That's mostly correct. The Ranger transitioned from OBD-I to OBD-II in 1995, and in fact, some later '95 builds are actually fully-OBD-II compliant.
Old Mar 8, 2008 | 07:57 AM
wendell borror's Avatar
wendell borror
Yeah and the first ones were very sensitive, by 96 would throw a code if I sneezed. I was taking it back to ford every couple of months to get checked and reset. Since I've had a 2000, 01 and 04 rangers, I modded them and everything else without throwing a code.
Old Mar 8, 2008 | 08:58 AM
Rockledge's Avatar
Rockledge
You can pull the codes yourself on the '94 without a scanner: ALTERNATIVECODE RETRIEVAL PROCEDURE FOR FORD EEC IV
Here's the same code-pulling procedure being performed on a '94 Taurus SHO. Notice that you don't need anything more than a paper clip to make the necessary connection: http://www.shophoenixproject.com/eec/eec.htm
Old Mar 8, 2008 | 10:41 AM
frdkid88's Avatar
frdkid88
yeah this truck only gets driven 10 miles a day and anything after 15 miles it will throw a code then it will go away.
Old Mar 8, 2008 | 11:25 AM
Rockledge's Avatar
Rockledge
Trouble codes can often be stored in memory even though the CEL is not on.
mike21105
Sep 8, 2016 02:18 PM
bbaudoin
6.7L Power Stroke Diesel
Apr 2, 2015 12:00 AM
Skarr
Jan 9, 2008 01:02 PM
meck1
May 11, 2007 04:42 AM
BAD ROD
Oct 15, 2003 07:51 AM
