Getting Warm
Old Mar 4, 2006 | 02:44 PM
Mike8623's Avatar
Mike8623
Getting Warm
Gentlemen, I just love my 96 powerstroke. Up until now the temperature has always stayed below the "N" in Normal. Now however the gauge is starting to show the engine getting a little warm........nothing over the middle of the gauge yet.......but now I have noticed that if I go slow.......it stays real cool.......when I speed up to 65 or so it starts getting warm.......when I slow down it gets cool again........any ideas. I keep the coolant changed and a new radiator was put in two years ago.....about 200,000 on the engine
Old Mar 4, 2006 | 05:18 PM
barebackjake's Avatar
barebackjake
kinda sounds like a tstat sticking partially open. not closed all the way at low speed and not opening enough at high speed.
Old Mar 4, 2006 | 06:58 PM
Mike8623's Avatar
Mike8623
Thanks for the post..........on a 96 just where is the thermostat located........On the end of the upper radiator hose there is a metal tube like housing that looks like it goes into the water pump.......is the thermostat between the end of the tube like housing and the water pump?
Old Mar 4, 2006 | 07:19 PM
barebackjake
thats where its at
the 203 t stat works great in theese trucks the only place that has the right one is dieselsite it has to be a long stem tstat the short wont work right. may as well buy a new tstat housing while you have that one off the tstat housing is lame and usually leaks if reused
Old Mar 4, 2006 | 09:13 PM
94 1/2 stroker's Avatar
94 1/2 stroker
Definatly change the tube or it'll leak. I got mine at oreillys for under $10.
Bareback does the 94's use the long or short ones?
Old Mar 4, 2006 | 09:22 PM
barebackjake
the 94.5-96 has a short stem 203 in it. in 97 they went to a long stem 195
Old Mar 4, 2006 | 10:16 PM
94 1/2 stroker
Thanks again bareback!
Old Mar 5, 2006 | 06:59 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Mar 5, 2006 | 08:01 AM
tjbeggs's Avatar
tjbeggs
napa has the 203 for 94.5 to 96. thats where i got my 203 stat for my 95
Old Mar 5, 2006 | 09:35 AM
Mike8623's Avatar
Mike8623
thanks
thanks to everyone that responded.........will order parts and put them in.
Old Mar 6, 2006 | 11:14 AM
weldboy's Avatar
weldboy
What advantage is the higher temp tstat? My 96 runs very cool and always has, almost never above the "N". I've never had a problem with it running this way, but do notice the exhust valve is annoying in the winter until the truck warms up. Will a 203 tstat warm the truck up faster and prevent the valve from closing as often?
thanks,
Jeff
Old Mar 6, 2006 | 12:36 PM
walt1968's Avatar
walt1968
thanks,
Jeff
You took the words right out of my mouth. I also have a '96 and with a bra over the entire grill, it might just touch the 1st bar in the normal range. I unplugged the temp wire that goes into the air box (plastic thingy) and the exhaust valve doesn't do that anymore!! Wicked annoying!!!
Old Mar 7, 2006 | 01:04 PM
1969fordguy's Avatar
1969fordguy
My truck seems to run cool also. I have heard the 203 thermostat makes the 7.3L run better and even pick up MPG. Sounds good, but I have yet to try it. Has anyone who has done this upgrade noticed an improvement aside from having hotter air for the defroster?!
Old Mar 7, 2006 | 09:58 PM
cookie88's Avatar
cookie88
FTE Emeritus
thanks,
Jeff
Diesels love heat. The higher the combustion temprerature you can maintain, the more efficient they become. Every notice how loudly your engine knocks on cold mornings? I'd run a 210 thermostat if I could get one.
Old Mar 7, 2006 | 10:05 PM
barebackjake
i got about 1-2 mpg out of the 203
carlgrover
1997 - 2003 F150
15
Feb 17, 2017 10:39 AM
Amicus
Mar 16, 2016 06:57 PM
Darrell Thompson
Jan 22, 2015 05:28 PM
riteprice
1997 - 2003 F150
20
Jul 2, 2008 01:28 PM
CharlesNeff
Jul 17, 2007 06:51 AM
