Bronco II Ford Bronco II
Gottoluvbronco 2
Old Mar 4, 2006 | 10:06 AM
paulgira's Avatar
paulgira
Gottoluvbronco 2
1989 Ford bronco 2 ,manual.2.9 cyc.Had new drake job to front 1 month ago an rear was fine,an it stops fine now.But this morning my rear anti-brake light came on an stays on.Friend says may be just sensor what does anyone think,your comments are important,thanks.
Old Mar 4, 2006 | 12:16 PM
bronocIInoob's Avatar
bronocIInoob
Did they change the brake fluid? Ive heard of good results from simply flushing the brake fliud to clean out the RABS valve that somtimes tends to get stuck.
Old Mar 4, 2006 | 04:01 PM
Desert Dog's Avatar
Desert Dog
Anti lock
I had to do a complete brake job front and rear flush the system then mine was ok and light went out.There is some way to pull codes off the antilock system maybe the site admin will answer in on this.
Old Mar 4, 2006 | 06:05 PM
Ken00's Avatar
Ken00
I would start with checking the fluid level, then make sure the rear brakes are adjusted properly, then pull the code (I have a link on this procedure in the tech info thread at the top of this forum), then do the brake fluid flush.
You did say if the red parking brake light stays on too.
Old Mar 4, 2006 | 08:13 PM
paulgira's Avatar
paulgira
Thanks alot,will check this things,an it is only yellow anti brake light that is on,bronco stops fine.Is it still ok to drive with light on,thanks .
Old Mar 5, 2006 | 04:49 PM
tchile's Avatar
tchile
abs light
just a long shot, mine comes on at times also, mine is due to the key switch not fully coming off the start position. try wiggling the key. i lost my radio during these phases too.
Old Mar 5, 2006 | 07:46 PM
Ken00's Avatar
Ken00
It's OK to drive, the brakes will work like standard brakes without RABS.
Old Mar 10, 2006 | 10:34 PM
paulgira's Avatar
paulgira
Thanks guys added brake fluild an yelloe anti ads lights off an brake pedal feela much better an yes stops better also,thanks alot
Old Mar 11, 2006 | 06:36 PM
Ken00's Avatar
Ken00
Glad to hear things are better!!!
90'F150
Jun 12, 2013 09:16 PM
baller9409
Jul 24, 2012 10:34 PM
mattri
May 18, 2009 09:02 PM
wmiller
May 22, 2008 06:33 AM
Saintelias
Sep 3, 2004 09:34 PM
