Sponsored by: Real Truck
Rumble in Front end
Old Mar 6, 2006 | 01:19 PM
99f350sd's Avatar
99f350sd
Ya with ball joints I hope. Both bearings can be changed in an hour... figure $100
Dick
Old Mar 6, 2006 | 02:48 PM
metalcaster's Avatar
metalcaster
Originally Posted by Mike Johnston
Several comments in this thread sound like needle bearings. They are not difficult to replace, and cost less than 15 bucks. My vibration/rumble would come and go, especially if I hit a small bump. Based on suggestions on this website, I checked the needle bearings. They were toast, and very close to ruining the axle. Don't put off fixing this. It could get expensive quick.
Mike Johnston
Are the needle bearings what the axle shaft run on? Located behind the upjoints?
Old Mar 6, 2006 | 03:31 PM
Mike Johnston's Avatar
Mike Johnston
Yep. All they do is support the weight of the axle stub. Pull the hub assembly and the needle bearings can be replaced from the backside.
Read this old thread: https://www.ford-trucks.com/forums/s...light=racerguy
Its a how-to on replacing the ball joints, but points 1-11 in the second post are the same as getting to the needle bearings. There are also photos associated with the thread.
04X
Oct 19, 2017 03:31 PM
vanlohd
Aerostar
16
Mar 22, 2004 11:03 AM
wacnstac
May 2, 2003 08:04 AM
agoldberg03
1983 - 2012 Ranger & B-Series
Feb 24, 2003 04:25 PM
