Need Measurement
Old Mar 3, 2006 | 05:41 PM
Stuffengineer's Avatar
Stuffengineer
Need Measurement
Hello
New to this site but not Ford trucks. Hope sombody out there could help me with a measurement. Need to know how wide the it is, outside to outside of the front tire tread on a 1986 F150. I bought one and have to pick it up. Would like to move it with tow dolly and need to know if it will fit. Unfortunatly I can't get the measurement through the guy I bought it from.
Thanks
Stuffengineer
49 F-47, 66 F100, 86 F150
Old Mar 3, 2006 | 06:15 PM
NavyMIDN08's Avatar
NavyMIDN08
it will vary, depending on what kind of tires he has on the truck. the most common is probably a 235/75/15 and a 31x10.5. of course, if the truck has oversized tires, it could be even bigger. if it's pretty much stock, you should be safe with a dolly that will handle a 10.5" tire width.
Old Mar 3, 2006 | 06:48 PM
Stuffengineer
Thanks
The tow dolly I have will fit 31 x 10.5's. Just not sure about the overal width outside of left wheel to outside of right wheel. Think that it would be around 73". Tires on truck are 235-15's.
Old Mar 4, 2006 | 07:06 AM
Stuffengineer
Need Measurement
Anyone have a tape measure?
Old Mar 4, 2006 | 09:02 PM
southernracer89's Avatar
southernracer89
is it a 4x4?
Old Mar 5, 2006 | 03:44 PM
Stuffengineer
Thanks
No its 4x2. Actually I just got back with it. Tread to tread its 73".
This just fit on the tow dolly. Actually one tire was riding high on the pan for the first 10 miles and then settled in. Towed fine. Seems this truck has a weak starter. It will turn engine slowly with the plugs out but not at all with them in. Tried boosting and bypassing the soleonid, makes no differance.
Old Mar 5, 2006 | 05:05 PM
Neb86's Avatar
Neb86
Check the ground wire from the battery to the engine.
my .02
crazytwo
Feb 16, 2014 01:05 AM
Stuffengineer
23
Jul 29, 2009 01:20 PM
josh86ford
15
May 22, 2009 06:14 AM
Skandocious
68
Jan 19, 2008 01:06 PM
Stuffengineer
Mar 6, 2006 05:50 PM
