Axle code
Old Feb 26, 2001 | 07:31 PM
loudfords's Avatar
loudfords
Axle code
Can someone please tell me what a 13J axle code translates to for a 79 F150.
Thanks, Chad.
1979 F150 Custom: 75 351W, Edelbrock & Holley
1987 F150 XLT Lariat: 88 351W EFI
Chevy 454: waiting for a truck (Mazda?Nissan?)
Old Feb 26, 2001 | 10:37 PM
StockMan's Avatar
StockMan
Axle code
[FONT COLOR="#0000ff" SIZE="3" FACE="Veranda"]
Try the VIN decoder found in the Tech Section in the right menu area.
[/FONT]
[LINK:www.hometown.aol.com/tbeeee|http://members.aol.com/tbeeee/page/registrysig.gif]
Old Feb 27, 2001 | 11:27 AM
loudfords's Avatar
loudfords
Axle code
Thanks for the pointer. It told me my truck has a 2.75 Ford rear. I also found out it was originally a 4 spd manual but was converted to C6 before I got it. I kinda wish it still had the 4 speed in it. Oh well, some time this summer it will get the AOD. The rear has also been replaced with a Dana 40 or 44 with 2.75 gear by one of the 8 previous owners.
Old Feb 27, 2001 | 12:43 PM
Franklin2's Avatar
Franklin2
Axle code
You are going to put an AOD with a 2.75 rear? I wonder if you
will be able to ever use the overdrive? On the interstate maybe?
Well, I think some mustangs had this combo, but they are not very
heavy vehicles.
Old Feb 27, 2001 | 03:23 PM
loudfords's Avatar
loudfords
Axle code
The 79 is probably getting the 8.8" rear from the 87 and the 87 will probably get the 2.75 9" from my 78 parts truck. I still need to find out what ratio is in the 8.8 (yes I do know how) and maybe switch to 3.55 gears. Then the AOD will be justified.
Old Feb 28, 2001 | 12:18 AM
fozzy's Avatar
fozzy
Axle code
I wish I knew what the hell the "J" stands for, I have the same code on my door jamb, and the rear tag says 2.75, but in my ford shop manuals for that year say nothing of a "J" it does have the 13 though...
Old Mar 6, 2001 | 12:20 AM
sleddingbetty's Avatar
sleddingbetty
Axle code
"J" is front axle code, if so exists, if yours does not have "J" it must be a two wheel drive!
Old Mar 6, 2001 | 03:35 AM
hotrodford_88's Avatar
hotrodford_88
Axle code
[font size="1" color="#FF0000"]LAST EDITED ON 06-Mar-01 AT 04:35 AM (EST)[/font][p]loudfords, you might want to rethink the rear end swap into your 87! It has rear antilock brakes, and the sensor is mounted in the top of the rear end. The 8.8 has an exciter ring inside that sends the signal to the ABS computer. The 9 inch you are talking about swapping in does not have any kind of provision for the abs sensor in the top of the axle housing. I figured this out when a buddy of mine offered me an 8.8 out of an 83 model. It doesn't have the provision for the abs sensor either. A simple way would just be to find a good set of gears and install them instead. It would save loads of headaches. Plus I think 87's and 79's used different width springs didn't they?
1988 F-150, SWB, 5.0 EFI (formerly 4.9 EFI), M5OD 5 speed, 3.08 gears, Summit shorty truck headers, Custom built Flowmaster exhaust system. Force 4 LP6000 lightbar, Federal signal PA-300 100 watt siren, Icom IC-V100 50 watt mobile radio.
1965 F-100 (just purchased 1/18/01), SWB, 390, C-6 auto. Dual exhaust, Not much else to do to it.
Can see both below.
[link:www.geocities.com/hotrodford_88/|Hotrodford_88's Webpage]
Old Mar 6, 2001 | 09:19 PM
fatforty's Avatar
fatforty
Axle code
Old Mar 6, 2001 | 09:24 PM
loudfords's Avatar
loudfords
Axle code
My truck has the 13J for an axle code even though its 2wd and has been all its life so I don't think J means front axle.
hotrod: Yes I know about the ABS in the 8.8 axle and that is one of the reasons I want to do the swap. That ABS has been nothing but a PITA. My 87 is a winter beater and as soon as you get on anything slippery the fronts lock up and you can't steer but because of the ABS the rears still push you around until you put it in neutral. I know the ABS is good on dry summer roads but thats not what I use the truck for. The ABS is all FUBAR anyways ever since I took the truck to the dragstrip and did burnouts with it. The ABS light comes on all the time now. I tried pulling the fuse to defeat the ABS but that made the problem worse than ever, no back brakes. Oh well, I guess I'll take it to the dragstrip on opening night again this year and thrash it
Old Mar 7, 2001 | 08:53 PM
Art's Avatar
Art
Axle code
[font size="3" color="#191979"]
J suffix means power steering.
Art
