Different carb for 300I6
Old Mar 3, 2006 | 12:25 PM
Rosie's Avatar
Rosie
Question Different carb for 300I6
I have an '80 f100 300I6 with a 1bb carb. The air cleaner on this is a real chore to get into.
Any ideas on what aftermarket air cleaner and carb to use? Would a carb from a 302 2bb or 289 work? I'm tired of fighting this air cleaner. It takes to wrenchs just to get the darn thing off the carb. Thanks for the help.
Old Mar 3, 2006 | 12:29 PM
mnmzimmer5's Avatar
mnmzimmer5
you can purchase after market air cleaners realatively cheap. I dont remember your truck's set up but thats where i would start first
Old Mar 3, 2006 | 12:47 PM
wtroger's Avatar
wtroger
Yours by your description has the heavy duty air cleaner my 86 Ford van uses it and yes it is a pain. My 1984 F150 has one the is simple and straight forward one wingnut bolt on top and it is off. So I would suggest going to the bone yard and see if you can find one from that era.
Old Mar 3, 2006 | 01:54 PM
fordborn's Avatar
fordborn
Thread moved to " Inline Six, 200, 250, 4.9/300" tech forum. Should find more resources for your question here.
Old Mar 3, 2006 | 07:46 PM
Rosie's Avatar
Rosie
Thanks for the tips. I'll look in a boneyard. I've tried after market aircleaners. after installing the adapter kit onto the carb, the aircleaner was too tall for the hood to shut. Maybe a different carb is in order.
Old Mar 7, 2006 | 01:31 PM
BigBear1's Avatar
BigBear1
Holley 390 carb/Offenhauser intake is a good choice. Clifford Intake or Edelbrock carb not a bad choice either
Old Apr 18, 2006 | 01:40 AM
AzRob's Avatar
AzRob
I welded some wing nuts to the bolt heads on my stock setup. Works real good, even marked the top and bottom parts of the air cleaner so I just glance at it when putting it back together.
Old Apr 18, 2006 | 04:23 PM
Rosie's Avatar
Rosie
Thanks AZRob. I have a wingnut on the underside of the aircleaner, but marking the aircleaner is a very good idea. Thanks!
Old Apr 19, 2006 | 12:04 AM
Bdox's Avatar
Bdox
Get a standard factory air cleaner from an 85-86 inline six. Very simple.
Old Apr 19, 2006 | 01:46 AM
Col Flashman's Avatar
Col Flashman
The Air Cleaner off of a '65 F-series, w/ a 4-v fits rather nicely & uses the wingnut attachment as well, install an Offenhauser "DP" Intake w/ a Holley 390cfm carb & a 2-into-2 Header so that you can make the 300 I-6 Breathe as it supposed to for best performance using just bolt-ons.
nineteensixt5f100
Aug 22, 2014 08:13 PM
41505379
Jul 19, 2013 06:55 PM
FordCardinal
Nov 24, 2006 03:25 PM
txwing
Feb 10, 2004 07:28 PM
mvee72
Mar 7, 2003 05:45 PM
