Big meats
Old Mar 7, 2001 | 10:02 PM
cypress_303's Avatar
cypress_303
Big meats
I have a '79 f-150, does any body know how big of a tire you can put on with out a lift, it's obvious i will need off set rims, but i would like to put 38" thornbirds this summer, but if they won't fit i have to put on 35"s, or buy a 3inch body lift, but hey it's all a big dent in my wallet.
thanx
Old Mar 7, 2001 | 10:10 PM
melovefords's Avatar
melovefords
Big meats
I have a 91 F150 and I went from the stock LT/235/75R15 to LT/285/75R16 and it fit just fine without a lift, I don't know if this helps you or not. I think these are equivelent to a 33 inch tire.
Old Mar 7, 2001 | 10:49 PM
ur2big1997's Avatar
ur2big1997
Big meats
i had a 79 ford it had a 6" lift and a 3" body lift.I ran 40" gumbo monster mudders on 10" steel wheels.i could run 44" but really needed finder triming.without a lift i bet 31 or 32 max and that would be close.good luck
Old Mar 7, 2001 | 11:57 PM
tetraruby's Avatar
tetraruby
Big meats
If you don't do the lift...I've got 31's on my stock 15" rims. There's no problem on a '79 F-100. Handles well. Any bigger and you might lose turning radius clearance.
Old Mar 8, 2001 | 10:00 AM
dre's Avatar
dre
Big meats
I have 31"x11.5" on my 78' F-150, with a 460ci setting on top
with small block coil springs.
No problem, big bumps no problem.
Dre'
1978 F-150, 460ci(750cfm,Edelbrock Performer,Dynomax Ceramic Coated headers,etc.)Auto-C6,3:70.1 - 9" Posi.
Old Mar 8, 2001 | 12:13 PM
dzjammer's Avatar
dzjammer
Big meats
I put 33's on last spring, mounted on Weld aluminum 15X10 wheels with stock backspacing and NO LIFT. The tires stuck out the side too much so I had to put fender flares on to save my paint. I have had no problems with them. If your not doing any rock crawling they work. The only other mod I did was spacing down the bumpstop so the tires wouldn't come up into the fenders under a heavy load. I used a 3x4 piece of steel tubing and bolted it in place of the rubber stop (which was gone on mine anyway).
Dave,
79 F-150 4x4, 390 w/C6, Edelbrock carb, 33X12.50 never will be finished.
Old Mar 9, 2001 | 12:03 AM
blaxuede's Avatar
blaxuede
Big meats
I Run 33's in my 79 f100 I have a 6 inch suspension lift but 33's are still cuttin it close
Old Mar 9, 2001 | 05:04 AM
tall1's Avatar
tall1
Big meats
I have a 79 with no lift (that I know of) and the 32's fit real nice. My friend has a 76 with a 4 inch susp. lift and 35's on it, but they will rub on the fenders in tight turns.
'79 F150 Stepside 4x4
351C-2V, 4 speed, 32/11.50 BFG MT's
'73 Mustang Grande
351C-2V, c-6
Old Mar 9, 2001 | 05:41 AM
77_F150_4x4's Avatar
77_F150_4x4
Big meats
I have no lift on mine i run 32x11x16.5 gumbo mudders in front and 32x18x16.5 tearra tires in back. I can fit 33s in there without problems.
Curtis
77_F150_4x4 aka
"The BeAsT"
Old Mar 9, 2001 | 07:54 AM
oz9609's Avatar
oz9609
Big meats
twwtruck
Offroad & 4x4
25
Feb 14, 2008 04:20 AM
bigun72
Offroad & 4x4
Feb 19, 2007 02:32 PM
bigun72
Feb 18, 2007 10:25 PM
redwood
Aug 4, 2004 04:56 AM
southerntoy
Nov 5, 2003 01:40 PM
