CCV Mod
Old Mar 2, 2006 | 01:26 PM
94 1/2 stroker's Avatar
94 1/2 stroker
Question CCV Mod
What do I need for the CCV mod? I just want to run it out the back for now. Thanks for the info!
Old Mar 2, 2006 | 06:37 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Simple = hose, clamps, cable ties ( disconnect CCV to intake tube, attach hose with clamps, route under truck to rear, secure to frame with cable ties, plug opening in intake pipe)
Old Mar 2, 2006 | 06:48 PM
pulnhorses's Avatar
pulnhorses
What is a ccv Mod? and what does it do?
Old Mar 2, 2006 | 06:58 PM
plowhand's Avatar
plowhand
Playing in the Dirt
"Crank Case Ventilation" The mod removes the connector to the intake pipe that puts the crank case oil vapors into the intake before the turbo. You just vent it to the outside (like a tractor) or pipe it into the exhaust to burn off the vapor.
Old Mar 2, 2006 | 07:45 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
check out my gallery "mods to my truck". yes its a 2002 but the same concept. i have mine tied into my exhaust. however on my 1995, i just did the CCV this past weekend. 3/4'' OD 1/2'' ID heater hose (red, same as in the pics in the gallery) and a hose clamp was all i needed. i was plumbing up a custom intake at the same time. all you would need a a 4'' piece of 4'' diameter exhaust pipe to replace that plastic POS junk that sucked in alot of dirt around that rubber elbow from the bottom.
SANDDEMON08
6.4L Power Stroke Diesel
59
Jul 31, 2018 03:22 PM
ChunderDownUnder
20
Jun 3, 2009 08:30 AM
tndiesel
20
Mar 11, 2009 03:24 PM
StrokeThis96
18
Mar 5, 2008 10:28 AM
7.3whitemonsta
16
Mar 31, 2005 04:53 PM
