Average MPG for a PSD
Old Mar 3, 2006 | 10:43 AM
jbread's Avatar
jbread
mpg
My 05 is stock. F250 CC with auto trans.
I get 10-12 city or highway. 6-8 towing 7K pound trailer going speed limit using cruise control.
I never use full throttle in normal driving, generally baby it.
Dealer has checked injectors, replaced exhaust sensor, did recall reflash.
Made no difference.
Good luck.....
Old Mar 3, 2006 | 12:10 PM
b_dub's Avatar
b_dub
05 4x4, banks monster exhaust, SCMT 1704,
14-15mpg average overall, driving it like I stole it.
Old Mar 4, 2006 | 12:43 PM
VonOverkill's Avatar
VonOverkill
Thumbs up Mileage:
17-19 M.P.G. mixed driving (doesn't get much better on freeway; 3000 RPM @ 88 MPH)
14.5 (stock mileage before changes)
'06 PSD King Ranch CC Dually Longbed
4.30 Rear Axle ratio
Edge Juice w/Attitude (upgrading to A2)
A.F.E. Stage II air system w/ProGuard 7
MBRP "Cool Duals" exhaust
Amsoil Series 3000 Heavy Duty diesel oil w/bypass filtration system
Pace Edwards Bedlocker motorized bedcover
MBRP Cat Converter delete (oops)
on 2nd set of factory BFG tires after 10K miles (he he)
Old Mar 4, 2006 | 06:46 PM
wesran's Avatar
wesran
04-cc-auto-28k miles getting 16-17 all around and 19-20 on interstate at 70 mph 1850 rpm. If the wife drives a full tank the milage will drop to 15-16 and hers is in the all around catagory. Use DFA in every tank.
wesran
Old Mar 5, 2006 | 05:20 AM
MobeyDick's Avatar
MobeyDick
How do you people get your Hwy. Miles vs. City Miles? I think I’m a fairly smart fellow, I drive on average 1,150 miles a week and 500 of those miles are on the Hwy and the rest are city. Now those Hwy miles and city miles are driven on a daily basis. So they can't be divided. What, unless you take 600 mile trips 20 times a year, does the Hwy miles tell you? What could those numbers possibly mean to any one? My stock 06 6.0 CC LB 4X4 averages 15.017 MPG. Driving 300 miles will not even come close to telling you your fuel mileage!!
Old Mar 5, 2006 | 10:28 AM
Customz's Avatar
Customz
I get 15 average with 35s
Old Mar 5, 2006 | 03:57 PM
wesran's Avatar
wesran
Well am not sure there is a fair answer to your question Moby but will try to explain my way of figuring hwy and all around, some times we may drive around here for a couple of months and the longest drive we will make is 50 miles and some of that can be on I 10 or I 49 but the bulk of it will be in the town of Lafayette, I call that all around driving and it may take a couple tanks of Diesel. I keep a record of every tank in an Excel spread sheet and it will spit out the miles per tank and then miles per gallon. Next if we make a trip to Houston, Gulfport or Monroe I will fill up before we leave and when ever along the way and each of these tanks are entered in the program giving off the results the same as before. Now granted this is not an over all average but does give you a good idea of yur milage per tank. Now if you want a yearly or 10k mile average I can change the formula and give that to you too. But I beleive in the text this thread was started, what I answered will be correct. By the way how did you come up with the 15.047 mpg?
wesran
Old Mar 5, 2006 | 05:42 PM
LVEILLON's Avatar
LVEILLON
Originally Posted by LVEILLON
I also get 15-16 city and 19-29 Hwy. I've only got 4000 on my 06 so I'm anxious to see what it gets at 12k-15K...I doubt it will get much better, but I'm pleased.
I meant 19-21 on HWY...certainly not "29"...
Old Mar 5, 2006 | 06:49 PM
6.0 Rules's Avatar
6.0 Rules
My truck ('03, 6.0L Lariat w/crew cab, short bed, bone stock) has gotten between 16-19 mpg city empty, and 10-12 mpg highway pulling a 6K# TT. It's done this since I purchased it new at Sunrise Ford in Fontana, CA. It now has 63K miles and getting the same mileage. I recently posted that my mileage had dropped off, but it turned out that I was not topping off the tank completely because of the foam in the fuel. If I stand there and continue filling for about twenty minutes, I can get consistent results on my calcs.
Old Mar 5, 2006 | 08:12 PM
hduplease's Avatar
hduplease
what will the mileage difference be between 410 and 430 rear end city and highway looking to tow a 15500 max weight trailer
Old Mar 6, 2006 | 09:11 AM
RickKimbrell's Avatar
RickKimbrell
Originally Posted by SDTruckMan
What can I expect for MPG on a 06 CC SB PSD..
average City-average Highway.
I have the Fx4 and 3.73 in that truck, stock except for a leveling kit installed, and with 3563 miles all of which is a mix of city-high on every tank, the best I can get is 13.7mpg.
DevotedDad
6.7L Power Stroke Diesel
29
Mar 6, 2020 01:51 PM
hinkle
Apr 26, 2014 10:18 AM
dentaldave
Oct 3, 2006 10:46 AM
cruisercroz
25
Apr 4, 2005 05:35 PM
JoeBoost
29
Mar 25, 2002 11:20 AM
