390 backfire through carb
Old Mar 3, 2006 | 01:48 PM
tastyklair's Avatar
tastyklair
Well to check if your valve adjustment is correct means actually checking the lifter preload on a hydraulic cam. There is a pretty good method on Cranes web site under the tech section. Basically with the piston of a given cylinder at tdc you should be able to spin the pushrod with your fingers feeling a little resistance but not free play.
dougx75
Jun 19, 2017 11:07 AM
csharris
39
Oct 7, 2016 08:23 AM
GrnMtn
New Member Introductions
Dec 18, 2015 01:47 PM
markeyd
25
Aug 30, 2015 08:52 PM
pward76
Jan 9, 2003 09:29 AM
