Headlamp Cover removal
Old Feb 28, 2006 | 09:50 PM
mrwolf's Avatar
mrwolf
Wondering if someone can help me out.
I have a 93 ford F350
I broke the clear running light plastic cover on the passenger side
I bought a new one but to install it I have to remove the entire
plastic frame
There are two scews at the top which are easy to get at
My question is how do I get to the bottom screws?
Old Mar 1, 2006 | 07:20 AM
TexasGuy001's Avatar
TexasGuy001
You have to remove the battery or the coolant recovery/windshield washer tank depending on the side your working on. There are 2 other nuts that hold the turn signal housing on. They are directly behind it. They arent too hard to get to but kind of a PITA. You will need a deep well socket and maybe a small extension. I can't remember what size it is.
Old Mar 1, 2006 | 07:01 PM
mrwolf's Avatar
mrwolf
Thanks Tex
I'll give that a try
Its a diesel so I have a battery on that side also
Old Mar 4, 2006 | 12:25 AM
LonnieD's Avatar
LonnieD
Wolf, I have the same truck and a similar problem...I've looked and looked and still can't find those dam bottom nuts people as talking about. If you find them please let me know..I have the two horns in the place they say the nuts should be..sure need help!!
Old Mar 4, 2006 | 04:39 AM
TexasGuy001
They are hidden back there. You can barely get your fingers on them. The best way to explain where they are though is directly behind the parking/turn signal light. This is the amber lense. They are in close to the same position as the 2 screws above the headlight on the plastic trim either chrome or grey. Maybe that will help you some. Also, be careful as they are easy to drop.
Old Mar 4, 2006 | 08:42 AM
mrwolf's Avatar
mrwolf
I found them...LOL
I had to remove the battery and the battery base
You cannot see the two bolts but they are there behind the plate the horns are
attached to
You can also see one bolt if you go under and look up
The access holes for these two bolts are just above the horns
They are a real pain to get at
Old Mar 4, 2006 | 10:46 AM
LonnieD's Avatar
LonnieD
I guess I'll remove the horns to get a better look. I had my battery bout, the tray removed everthing ..still couldn't see them..but I'll try one more time before Ford gets her
Old Mar 4, 2006 | 03:44 PM
mrwolf's Avatar
mrwolf
No need to remove the horns
The access holes to get at the nuts are just above the horns
They are right where Tex says they are
You cannot see them but they are there
Takes a 7/16 long socket to remove them
Hope this helps
Old Mar 4, 2006 | 08:06 PM
LonnieD's Avatar
LonnieD
Ok I'll try but last I looked there wasn't any nuts or even holes...just sheet metal (put of the front end...but we'll again thanks
LonnieD's Avatar
LonnieD
Sorry that should have said (part of the front end)...
Old Mar 5, 2006 | 12:42 PM
ncranchero's Avatar
ncranchero
The parking light is mounted to the headlight "door", #11. Remove two screws #2 and 1 nut #9 and pull the "door" off.
josephavellino
Apr 3, 2015 07:16 AM
tbugher62
Feb 8, 2014 12:38 AM
snowdawg
1983 - 2012 Ranger & B-Series
Apr 16, 2013 12:02 PM
RedBoat
23
Oct 3, 2007 09:28 PM
GeneStoner
Jan 7, 2004 08:54 AM
