Easily ID 460 engine
Old Mar 3, 2006 | 06:14 PM
quehele's Avatar
quehele
385seriesHemi wrote:...yea, it looks like a 3 now since i just got done cleaning it off all the way.
Glad I could help. Say, how close is Bloomington to Duluth? My family is from there. "Shaw" is our name...
Old Mar 3, 2006 | 06:16 PM
banjopicker66's Avatar
banjopicker66
..windsor is mounted on the intake..
Oops. Tells you how much I know about Windsors!
Old Mar 3, 2006 | 06:28 PM
quehele's Avatar
quehele
Mr. MonsterBaby has a point. The head casting numbers for Ford/Lincoln/Mercury look like this:
First number = Decade of production
"D" = 1970 to 1979
Second number = Year of production
"3" = 1973
There was no "4", "5", "6", "7", so there can't be an "8".
Third number = Model
"A" = Ford
"V" = Lincoln
"T" = Truck
Forth number = Engineering group
"E" = Engine
Hope this clears things up...
Old Mar 3, 2006 | 06:34 PM
monsterbaby's Avatar
monsterbaby
actually that casting number idea doesn't work, the block, and head casting numbers on these engines is actually a casting revision number not a date casting number (that can be found in another place) The D3VE casting number was the revision to the heads that was made in 1973 and that casting was used clear up into the 80s with the advent of fuel injection although there does appear to actually be a few E5 and E6 castings.
Another example of this is the blocks in 1971 they revised them for slightly taller deck hieght and that revision number is D1VE, there might be a suffix after that also such as A2B that indicates a further minor revision. the casting date on the block is in thelifter gallery. The next revision was D9TE, which was in 1979 as you would guess and that casting number was used on all blocks up until the end of the 460s in 1997.
Old Mar 3, 2006 | 07:35 PM
olfordsnstone's Avatar
olfordsnstone
If stock valve covers, I have found that the easiest and most stand outish sign of a 460 is the valve covers. They were the same for the 429's and 460's for most all of the early years, and in a 78/79 truck, I would say it is a relatively early engine. The valve covers were kind of squared off, and flat on top. Once you see one, you'll know the look.
BTW, even if the truck you're looking at has a 429, you'll be happy with it. 429/460 engines are both a very good choice for that truck, IMO.
It probably is an engine swap out of a Lincoln. Mine is and runs like a stripe azz't ape.
jamusfam
Apr 25, 2014 10:38 PM
393STROKER
31
Jun 20, 2009 12:23 PM
Farmtwin
Mar 23, 2006 01:28 AM
1987blueovalcrazy
Aug 28, 2003 08:05 PM
79_custom
Jun 12, 2003 07:09 PM
