Sponsored by: Auxito
Instrument cluster question on park indicator
Old Feb 28, 2006 | 01:11 PM
supertruck's Avatar
supertruck
I have the rest of dismantling down to a science from a previous project,but how or where do I disconnect the park indicator on instrument cluster...the cluster bulbs I repaired earlier was in a standard tranny 98 ford....this one is my 97 supercab with an auto.....thanks
Old Feb 28, 2006 | 02:40 PM
qdude79's Avatar
qdude79
If I remember correctly from my '99, it's a spring loaded wire that hooks to a white plastic piece. Remove the screw from that plastic piece and the indicator wire is free. Look under the dash while moving the shifter up and down and you should see the wire moving.
Old Feb 28, 2006 | 02:41 PM
supertruck's Avatar
supertruck
I didn't notice a screw on mine...but I'll do a double take......thanks
Old Feb 28, 2006 | 05:12 PM
steve(ill)'s Avatar
steve(ill)
i think i left the plstic piece on the end of the cable, slide the plastic piece out the its holder and just push the whole thing out of the way and lift the dash over it.
Old Feb 28, 2006 | 06:16 PM
supertruck's Avatar
supertruck
i actually managed to leave it all in tact and swapped all the burnt out bulbs....didn't realize that the bulbs behind the speedo were smaller than the other four for the guages...LOL...we got'er though
