Flooded Engine
Old Mar 19, 2001 | 11:51 PM
blaxuede's Avatar
blaxuede
Flooded Engine
I was just wondering what is the best way to "unflood" and engine. I just rebuilt my engine but my parents made me move my truck from the shed to the outside cause they wanted to clean out the shed. Of course it rained like a bitch all week and then when I went to fire it up on saturday the cylinders and the intake were completely filled with water it wouldn't even turn over. I covered the engine up with a tarp but I guess water leaked through my air filter through my carb and through my intake. Anyways. I took the plugs out and the spark plugs and turned it over and flushed most of the water out. I did it again today and no water was in it, so I sprayed some WD 40 in the cylinders to prevent it from rusting and put the plugs back in. Would this work and what else should I do to get the engine prepped for starting. It hasn't Run since Dec 31 2000, new rings, piston, con rod bearings, seals and gaskets.
Thnx , Gord
Old Mar 20, 2001 | 01:12 AM
Nathan's Avatar
Nathan
Flooded Engine
I would leave the plugs out for a while to let any moisture evaporate. the WD40 is a good idea. Then change the oil before starting. I would then change it again after a short run.
Nathan
Old Mar 20, 2001 | 06:41 PM
fozzy's Avatar
fozzy
Flooded Engine
there is a product called "WIRE-DRYER" it is used for wet electrical components like distributors etc, it evaporates quickly taking the water with it.it also dries clean with NO residue. shoot a little in each cylinder then re-oil them untill starting
https://www.ford-trucks.com/dcforum/User_files/3a9df0394b631ce6.gif
77'FORD F150 XLT 400
Old Mar 21, 2001 | 05:33 AM
jeff70's Avatar
jeff70
Flooded Engine
if it was me I would take all the plugs out and turn the motor by hand a couple times to get the as much water out as possible then spray it down with some type of lube and crank it over. The same thing happened to me except I tried to jump a stock dam and ended up in the middle with water up to about the middle of my doors....ah the joys of youth. Anyway after we pulled it back home I did that then changed oil a couple times and shes still running.
Old Mar 21, 2001 | 09:32 PM
blaxuede's Avatar
blaxuede
Flooded Engine
K thanks guys. I need some more info on this though. I just put my intake back on today after cranking it over a couple times. I put my intake and carb back on, pumped the gas a couple times and turned it over, not even a cough. I took one plug out and shot some gas into the cylinder, put the plug back in and turned it over. It back fired, probably the loudest backfire I've ever heard. I know I have to re-time it, but do you have any tips on timing and how I should tune it up? I also changed the oil too it was ##### gross, white as my #####. So what should I do ?
Old Mar 22, 2001 | 10:34 PM
400HP794x4's Avatar
400HP794x4
Flooded Engine
I'd tear it down, see what was going on with the cylinders. That really sucks man
Old Mar 23, 2001 | 06:36 PM
blaxuede's Avatar
blaxuede
Flooded Engine
ok, I finally found out why my truck wouldn't fire, my valve timing was out about 9o degrees, so I tore my water pump off and my rad and took the timing apart and found out the vqalve timing was out almost 90 degrees. it almost started yesterday after we fixed the timing AND it started at ran for about 5-7 seconds. What's wrong with it?
Old Mar 23, 2001 | 07:46 PM
proud66owner's Avatar
proud66owner
Flooded Engine
beemr
Jan 10, 2013 12:08 AM
Molineguy
Oct 10, 2011 09:09 PM
Quick444
Oct 4, 2009 08:40 PM
adodge2000
1983 - 2012 Ranger & B-Series
Mar 12, 2006 11:09 AM
ford_mudd_runner
Sep 27, 2005 08:34 PM
