c6 tranny coolant lines.
Old Mar 21, 2001 | 09:41 PM
tbejr's Avatar
tbejr
I think I mixed up my coolant lines installing my c6 in my 70 f100 with 360/c6.
one by bellhouseing and one by tailshaft? where do they go?
thanx. Thomas Endicott
Old Mar 21, 2001 | 11:23 PM
HiMe's Avatar
HiMe
Tailshaft line to right side of radiator; bellhousing line to left side of radiator. Your lines must not be oem style, because they can only fit one way (the correct way).
Old Mar 23, 2001 | 05:28 AM
gadams's Avatar
gadams
I wouldn't think it should matter. It's just a small radiator section, and the direction of flow through it wouldn't matter would it?
I could be *TOTALLY* wrong here, though, so follow that other guy's advice.
Greg
67 F100 CCS 390
Old Mar 23, 2001 | 06:07 AM
jowilker's Avatar
jowilker
Greg I'm glad you posted that, because when I read it yesterday, that is exactly what I was thinking. I bought two 5ft lines and it worked out that the drivers side went to the front and the passenger went to the rear..
I am of the opinion the it like the heater core doesn't matter which side is which. Can anyone offer anything to change my mind.
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quite of night you can hear chevies rusting away.
Old Mar 23, 2001 | 06:32 AM
jowilker's Avatar
jowilker
Old Mar 23, 2001 | 10:44 AM
mattb's Avatar
mattb
i agree 100% when i had my trans built i asked the builder, if it mattered and he said nope.
matt
Old Mar 23, 2001 | 01:56 PM
beartracks's Avatar
beartracks
Unless you also have an external cooler or filter.
1977 Ford F-100
400m/c6
280,000 miles
Stock on the outside
modified/rebuilt everything
Old Mar 23, 2001 | 11:02 PM
BB's Avatar
BB
HiMe is right, there really is a correct way to installing these lines. The return line should be connected to the fitting that is farthest away from the water outlet, whether vertical or horizontal style radiator. It is thermally more efficient that way when you consider the direction of the hot fluid flowing through the cooler vs. the coolant flowing around it. Don't know how much of a difference it makes though. Add-on coolers should also be installed in the return line too. This is the line that goes to the back of the trans.
Barry
tbejr
Sep 11, 2001 07:02 PM
tbejr
Apr 19, 2001 03:45 PM
tbejr
Mar 26, 2001 10:09 AM
Thomas Endicott
Dec 14, 1999 09:16 PM
Thomas Endicott
Sep 22, 1999 12:22 AM
