c6 shifting points
Old Mar 24, 2001 | 01:23 PM
tbejr's Avatar
tbejr
c6 shifting points
I have a 70 f100 with c6/360. I just installed a c6 from wrecking yard. It shifts from 1-2nd at 5mph and 2-3rd at 15mph. what do i have to adjust/fix this? modulater controlled?
Thanks Thomas Endicott
Old Mar 24, 2001 | 06:04 PM
jbhf250's Avatar
jbhf250
c6 shifting points
>I have a 70 f100
>what do i have to
You will have to have the `KickDown` linkage from the carb to trans installed... Then try turning the modulator screw IN..
Its up inside the `tube` where the vacuum hose connects to the modulator.
Check how it shifts at wide open throtle for the MAX setting!!
__JOHN__Õ¿ö
FTE Club #7
Member-
http://www.cruisin-north.com/
Santa Rosa, Calif.
72 F-250
ICQ#6030753
http://www.ford-trucks.net/users/jbhf250/
https://www.ford-trucks.com/pictorial/big/1972_f250_2.html
Old Mar 25, 2001 | 10:49 AM
tbejr's Avatar
tbejr
c6 shifting points
So that screw is there for adjusting the shifting times?
Old Mar 25, 2001 | 04:33 PM
jbhf250's Avatar
jbhf250
c6 shifting points
YES ....to a point. a slight adjustment can be done there.
__JOHN__Õ¿ö
FTE Club #7
Member-
Santa Rosa, Calif.
72 F-250
ICQ#6030753
Old Mar 25, 2001 | 10:09 PM
fatforty's Avatar
fatforty
c6 shifting points
Hi, sounds like the kickdown linkage isn't adjusted right.
John
Old Mar 25, 2001 | 11:49 PM
oz9609's Avatar
oz9609
c6 shifting points
Adjust the modulator screw in for later, firmer shifts. Out for earlier, softer shifts.
Shorten kickdown linkage for earlier full throttle shifts and lengthen for later full throttle shifts. Adjustment is at carb.
Old Mar 26, 2001 | 10:09 AM
BB's Avatar
BB
c6 shifting points
tbejr
Sep 11, 2001 07:02 PM
tbejr
Apr 19, 2001 03:45 PM
tbejr
Mar 23, 2001 11:02 PM
Thomas Endicott
Dec 14, 1999 09:16 PM
Thomas Endicott
Sep 22, 1999 12:22 AM
