Crank undersize limites?
Old Feb 27, 2006 | 12:53 PM
flexybronc's Avatar
flexybronc
Well my cam went out in a hour of run time with the wrong oil restrictor kit that i put in. So i pulled it apart to find that it junked all the bearings minus the cam bearings while also grinding some nice grooves in the crank. The crank is a the very bottom of the spec for .020 under already. Is it safe to go .030 under i know they make bearings for it but its just kind of iffy. I am going to put the thing through some abuse so i firgured i would ask.
Old Feb 27, 2006 | 01:02 PM
bmc69's Avatar
bmc69
They'll go .040..at which point I think there are no more bearing options that I know off. There is plenty of meat on those bones..that is not an issue.
Old Feb 27, 2006 | 07:31 PM
grclark351's Avatar
grclark351
the cam bearings are OK? an oil restrictor kit would not cause cam lobes to wipe. the typical oil restrictor kit for these engines restricts oil to the cam bearings to save the oil for the crank.
Old Feb 28, 2006 | 06:41 AM
flexybronc's Avatar
flexybronc
Ya the cam bearings are spotless. I just know that the kit i put in (now i know anyway) being the five peice moroso kit is not to be used with hydraulic lifters. All i know is that one lifter was callapsed, 3 others were ground off big time, and 2 cam lobes where worn off bad.
Old Feb 28, 2006 | 05:17 PM
dkstuck's Avatar
dkstuck
what kind of oil or additive used for breakin?
Old Feb 28, 2006 | 05:32 PM
Torque1st's Avatar
Torque1st
Posting Legend
Use diesel engine oil for cam/engine break in.
When an engine destructs that way small particles of metal are carried thru the oil into all of the bearings. The filter only stops a certain % of the particles (called beta ratio in the filter engineering world). The particles embed into all of the bearings and essentially ruin them so they should ALL be replaced. Bearings are made to absorb those particles but they will only absorb so many.
Your oil pump will need to be replaced also.
Old Mar 1, 2006 | 10:27 AM
beartracks's Avatar
beartracks
A good flushing of the block etc. is also in order so hidden junk doesn't come back to haunt you.
Old Mar 1, 2006 | 05:56 PM
ReGGaTarT's Avatar
ReGGaTarT
What part number is the Moroso oil restrictor kit?
Which oil restrictor kit should be used with hydraulic lifters?
Old Mar 1, 2006 | 08:19 PM
Modified's Avatar
Modified
Hey REG,
If you check out TMI's post about oil pressure on the 400 you see that the most important thing is the clearance between the bearings and the crank. check it out!
Old Mar 1, 2006 | 08:24 PM
ReGGaTarT's Avatar
ReGGaTarT
ok I will look for TMI's post. Thanks Modified
Davehart24
Feb 12, 2014 02:45 PM
Davehart24
Feb 10, 2014 03:20 PM
velcro7279
4 Cylinder Engines
Jul 30, 2009 06:57 AM
76 F250 4X4
Nov 7, 2004 11:42 AM
boldtvillekid
Jul 19, 2003 11:57 PM
