400 bad cam bearings?
So i tore my 1977 f250 400 apart the other day to put a mild cam in it and when i took the old cam out i noticed the cam bearings looked horrid. They were cracked and even missing small chunks. What could have caused this? is there anyway to replace them without dropping the crank? could the crank be damaged also? i noticed small scoring in one of the cylinders also. Maybe time for a shortblock? thanks alot!
Sounds like a bottom end rebuild or a whole new shortblock to me! Has it over heated or lost oil pressure? Both can trash bearings.
If you do need a rebuild you could probably get away with just honing and oversized rings for the cylinder walls. As far as the crank, pulling it will give you the best understanding of the damage.
MattMac
36
04-27-2017 07:12 AM
brokersteve
07-21-2014 02:21 AM
shorty2tall
12-15-2010 04:08 PM
