Vibration when put into gear
Old Mar 1, 2006 | 12:38 AM
red65crewcab's Avatar
red65crewcab
I am working on a 1978 F150 4x4 that has a 351 4bbl clevland in it. When I but it in any gear it real shacks the truck. The truck stuters a little at initial take off . I am also having backfires through the carb when trying to accerate. Can you give me your opinions.I bought the truck with the motor already in. Drives down the road with out vibration. Thanks
Old Mar 1, 2006 | 01:13 AM
Torque1st's Avatar
Torque1st
Posting Legend
Automatic or manual transmission? How many miles on the engine?
Old Mar 1, 2006 | 08:03 AM
cwheel's Avatar
cwheel
Some possibilities:
Bad engine mounts
Slop in the driveline - maybe one of the U-joints, or even a differential
Timing - check this just to be sure (backfiring out the carb could be an indication of the timing being off)
Dumb question, but you don't have it in 4WD do you?
Old Mar 1, 2006 | 09:05 AM
red65crewcab
It is an Automatic. Mileage is unknown.The shacking takes place as soon as you put the truck in gear with the brake applied and still stopped.As you take off truck stuters alittle and the goes fine. Thanks for any help provided
Old Mar 1, 2006 | 01:41 PM
tastyklair's Avatar
tastyklair
Check the basics. Make sure the wires are in the correct order. Check for vacuum leaks and timing.
Old Mar 1, 2006 | 06:06 PM
Torque1st's Avatar
Torque1st
Posting Legend
A shudder like that would probably just be a misfire from a bad plug, valve, wire, or even a carb problem.
Old Mar 1, 2006 | 08:33 PM
red65crewcab
Thanks for the help everyone. I installed a reman Distibutor and everything seems to be fine.Thanks again
