Steering troubles
Old Mar 27, 2001 | 10:03 AM
rfgre's Avatar
rfgre
Steering troubles
On my '78 Exployer shortbed pickup F-100 with power steering I'm having a problem which is begining to annoy me. I've replaced the steering box and that improved it somewhat, then the rag, that helped, can't find any loose or worn parts in the front. I'm still having a problem with what I call over steering. You turn the wheel just enough to go to the other lane but there is a one second delay before she responds.When I first bought the truck she was all over the road and now I'm down to this. by the way I had to drop the steering colume to replace the rag. Is there a faster way? What would that be? ALSO... is it just me or what? Seems like the '73 to '79 Ford pick-ups are more popular and cost more in top shape then the '67 to '72... What's everybodys opinion on this topic??.....
Bob
Old Mar 27, 2001 | 03:51 PM
390fe's Avatar
390fe
Steering troubles
Bob, does your '78 have a tilt column? Mine does, and the u-joint for the tilt is shot. I'm planning on replacing the column with one in better shape, or just using a non-tilt column. Tearing the column apart to get to the joint looks like a lot of work.
Jason Kendrick
1970 F100 Custom 390/C6
1978 F150 Ranger Lariat Supercab 460/C6
Old Mar 27, 2001 | 04:40 PM
rfgre's Avatar
rfgre
Steering troubles
Jason.
I didn't take the coloum apart, I just let it drop down so things wouldn't be so tight making it easier to get the rag off. How would you do it? No I do not have a tilt.
Bob
Old Mar 27, 2001 | 07:47 PM
BigBrownTruck's Avatar
BigBrownTruck
Steering troubles
fordsforever2015
Nov 12, 2021 11:35 PM
vidaliaman
May 4, 2016 07:59 AM
krazyness
Sep 10, 2015 04:36 PM
stercorarius
Mar 14, 2015 11:15 PM
hickorycornerfarm
Jan 31, 2012 04:13 PM
