Rag Joint Trouble
Old Jan 31, 2012 | 08:27 AM
hickorycornerfarm's Avatar
hickorycornerfarm
Rag Joint Trouble
Hello All, I have a '78 150 that I'm attempting to replace the rag joint on. My shaft on the steering box is 3/4" and I've ordered a couple used and NOS rag joints (I've ordered a couple over the past month hoping the problem was a mix up in part numbers). I have the same problem with each one I've gotten. They measure in at 11/16". Everybody that I've purchased from tells me this is for a 3/4" shaft. I don't feel that persuading it with a hammer is the right thing to do because I don't see where there is any room for expansion the way these are built. Has anybody else ever experienced this problem? Is it possible they are intended to be pressed on? Thanks, Brian
Old Jan 31, 2012 | 02:32 PM
mjshagnasty's Avatar
mjshagnasty
you could always just order a vibration damper from summit...
Vibration damper - Steering U-Joints - SummitRacing.com
find the one that you need
or
a rag joint from summit
Rag joint - Steering U-Joints - SummitRacing.com
Old Jan 31, 2012 | 02:48 PM
JB78f150's Avatar
JB78f150
Have you looked at the ones in the Help! section of your auto parts store. It worked fine for me.
Old Jan 31, 2012 | 02:54 PM
Blown 331's Avatar
Blown 331
I bought a Dorman from Rock Auto.com. Worked great. It sound to me like you need to hammer it on there.
Old Jan 31, 2012 | 04:13 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by hickorycornerfarm
Hello All, I have a '78 F 150 that I'm attempting to replace the rag joint on.
Please, when asking questions, list all the pertinent info. Assuming you have an F150...
Here's the reason why you keep buying the wrong part: 1978 F150: There are FOUR different steering couplers (rag joints).
D6TZ-3A525-A = 1978 F150 4WD with Manual Steering,
D9TZ-3A525-A = 1978/79 F150 4WD with Power Steering.
D8TZ-3A525-A = 1978/79 F100/350 2WD with Power Steering.
D8TZ-3A525-D = 1978/79 F100/350 2WD with Manual Steering.
So, which one of the above matches your truck?
shorerider16
18
Jul 22, 2016 06:48 PM
abyars111
Mar 7, 2013 10:07 PM
OilLeaks
Feb 8, 2006 08:40 PM
