1978 - 1996 Big Bronco
corrosion control
Old Feb 27, 2006 | 12:04 PM
460srule's Avatar
460srule
corrosion control
Has anyone had any exprience with electronic corrosion control devices?Do they work or are we talking "smoke and mirrors"? The hype sounds good but should a person invest?
Old Feb 27, 2006 | 02:17 PM
wozxxx86's Avatar
wozxxx86
well rust is caused by the electons leavein iron. so mayb
Old Feb 27, 2006 | 02:39 PM
Will_01_GT's Avatar
Will_01_GT
I have a 96, live in a salt and winter region, I've just noticed a dime size paint bubble over a rear fender. How much are they? Every thing rusts at some point, Maybe I've been lucky
Old Feb 27, 2006 | 06:01 PM
greystreak92's Avatar
greystreak92
While you are at it by a throttle body spacer and some snake oil.
Old Feb 27, 2006 | 07:38 PM
Streetgang's Avatar
Streetgang
I concur 100%.
Old Feb 27, 2006 | 08:36 PM
roscoe's Avatar
roscoe
It would be alot easier and cheaper to buy a garden sprayer and spray some used motor oil cut with kerosene on the underside and over the wheel wells, below the tail lights, etc. If you see an older rust free truck up here, chances are the owner sprayed it 2 or 3 times a year.
Old Feb 27, 2006 | 09:08 PM
96Broncowner's Avatar
96Broncowner
Cool
Hey Will_01_GT, I had the same paint bubble and decided to open it and try to touch it up. Really bad idea unless you are better with paint than I am. I went from a small bubble to a large eyesoar. I agree that everything eventually rusts, expecially if you live in the great white north. Most of my DMV taxes pay for road salt.
Old Mar 4, 2006 | 01:49 PM
bossind's Avatar
bossind
used motor oil doesn't work, washes off too fast. I live in canada so I know. There is a product from prolab that works pretty good, but nothing works better than keeping her clean underneath and cleaning those spots that hold crap, like above the inner fenders over the rear tires.
Old Mar 6, 2006 | 02:49 PM
Roushians's Avatar
Roushians
How do you go about cleaning those inner fenders??
currently, i just stick the pressure washer nozzle down the square hole above the wheel wells on the box. the first time i did that (after a few months of winter), tons of dark liquids washing out underneath (i suppose built up salt and dirt) so it worked a bit.
sudsmcduff
Oct 19, 2014 02:30 PM
CPB1
Jan 26, 2014 04:35 PM
Pitcrw6
19
Jun 19, 2012 04:19 PM
xpinoyxhc
1983 - 2012 Ranger & B-Series
Nov 30, 2008 12:27 PM
teg3
Aerostar
Jun 17, 2005 05:56 PM
