2000 Expy accel pedal sticks?
Old Feb 27, 2006 | 08:45 AM
adamg101's Avatar
adamg101
I have a 2000 EB Expy with adjustable pedals. I have a problem with the accellerator pedal sticking only after the truck has been sitting and I first start her up. I really have to hit the pedal hard once for it to work. After I get moving everything works fine. No sticking at all. Did some searches, but no luck. Any ideas??
Thanks, Adam
Old Feb 27, 2006 | 08:47 AM
jas88's Avatar
jas88
You need to have your throttle body cleaned.
Old Feb 27, 2006 | 11:28 AM
pitrow's Avatar
pitrow
yep, what jas88 said. I had the same problem with mine a while ago. You get a buildup of gummy crud in the throttle body seat and the throttle valve will stick to it, especially when it sits for a while. It then takes a little pressure to pop it loose.
The fix is easy, get a can of sensor safe carb cleaner and a rag. Take the intake air hose off the throttle body and go to town with the carb cleaner. Make sure to use the rag and wipe off any stubborn deposits on the little lip in the throttle body as while as off of the throttle valve itself. Put it all back together and you should be good.
Old Mar 8, 2006 | 08:03 PM
pcwooten's Avatar
pcwooten
Thumbs up THANK's
Thank you ,I came here hoping to find a thread on this !!! thank you again
Old Mar 8, 2006 | 09:42 PM
cds's Avatar
cds
Make sure it is Teflon safe as well. I have cleaned mine 2 times in 2 years and just cleaned my mom's due to sticking. Not difficult at all.
Mazz
May 5, 2014 09:53 PM
ampslw
Jun 24, 2012 01:31 PM
jasonfusillo
Aug 23, 2011 09:50 AM
turboman24
16
Jul 4, 2010 10:03 PM
shovmyfist
Jan 23, 2003 09:59 AM
