U-joints
Old Feb 26, 2006 | 10:19 PM
4x4bigblock's Avatar
4x4bigblock
U-joints
How can i tell which one i have? I need 2 for the front drive shaft of a divorced drive line. in my 73 f 250. Should i buy exspensive ones? or just get em from advanced or auto zone?
Old Feb 26, 2006 | 10:31 PM
Torque1st's Avatar
Torque1st
Posting Legend
If your joints are not stock you can measure them by diameter of the caps and distance across the caps.
Old Feb 26, 2006 | 10:54 PM
fordraceboy's Avatar
fordraceboy
get spicer's if you can, they seem to last the best for me..
Old Feb 26, 2006 | 11:05 PM
Mil1ion's Avatar
Mil1ion
Buying the PROPER U-Joints sucks.
There are so many applications listed.
Old Feb 26, 2006 | 11:41 PM
4x4bigblock
where do they sell spicers? and do all u joints have grease fittings?
Old Feb 27, 2006 | 01:10 AM
ivanribic's Avatar
ivanribic
Most Napa stores will sell Spicer u-joints but you have to ask for them specifically or they'll hand you the Japanese junk in the Napa box. They'll cost more money but they're a lot stronger. My advice on any Ford driveshaft u-joint is to take your old u-joint in with you when you get the new set. Ford seemed to mix up a lot of stuff with these and often times what the store's book says should fit will not. Have them compare the two side by side with a tape measure and calipers on the caps. This will save you a half dozen trips to the parts store . . . been there done that.
Btw, not all u-joints have grease fittings. If I remember right the Spicers are sealed and never need greasing.
Old Feb 27, 2006 | 09:07 AM
MBBFord's Avatar
MBBFord
I want to say you should have 1310 u joints, but thats only what I've seen in books, like Ivan said for did change those up, and who knows.
But if it is 3.5" wide, it should be 1310s.
Old Feb 27, 2006 | 10:57 AM
460's Avatar
460
Spicers are available both ways, greasable and not. I use Spicer greasable-thru-cap u-joints in my axle shafts for the front. I wish my Napa could get them, but they can't. Luckily for me though, there is a 4x4 shop only 9 miles away.
For my 4x4 trucks I prefer greasable fitting because they spend most of they're life under water, but on anything else the non-greasable Spicers do fine - I have 110,000 miles on the non-greasable Spicers in my daily driver and they just recently started to squeek.
Old Feb 27, 2006 | 02:00 PM
Torque1st's Avatar
Torque1st
Posting Legend
Surprisingly the non greasable versions often last longer due to the fact that people do not force dirt and grit thru them along with the grease. Many people do not clean the zerks before they fill them with grease. Even if the zerks are wiped off there is still a circle of dirt around the ball seal which is enuf to destroy the bearings. If the joints spend a lot of time under water there is not much you can do but force copious amounts of grease thru them and pray. When a hot U-joint is suddenly cooled by immersion in water they will draw water (and grit) in past the seals.
JRS2
May 26, 2016 06:15 AM
74Mav
May 10, 2016 07:31 AM
jayloveland
Mar 28, 2015 01:52 PM
sammydiesel
13
Dec 10, 2009 04:42 PM
62 unibody
Sep 22, 2004 03:36 PM
