thinking about deleting the muffler
Old Feb 26, 2006 | 10:17 PM
guthrie&co's Avatar
guthrie&co
I have a dynamax 4 inch from the turbo back. it has a muffler in it and i am thinking about deleting it and making it a complete straight pipe. how much louder in the cab will it be and what are the down falls to a straight pipe. any gains?
Old Feb 26, 2006 | 11:05 PM
MRBASS's Avatar
MRBASS
You wont notice any difference in the cab,Will make a good difference in the EGT,, if thats an issue. I always felt just improving flow was the greatest benefit.
Old Feb 27, 2006 | 12:27 AM
jtharvey's Avatar
jtharvey
I will disagree with MRBASS on seeing any difference in EGTs. The reason is, your 4" system that you have now most likely already has a straight thru muffler on it, with virtually no restriction. Adding a straight pipe wouldn't gain you anything in this case, except for it being louder. It will most likely give you some drone in the cab, especially on the highway, which I personally found rather annyoing and put my muffler back on. However, it also provides a good bit of sound outside the cab.
It just depends on what you're after. What are your goals with going to a straight pipe?
Old Feb 27, 2006 | 12:58 AM
guthrie&co's Avatar
guthrie&co
for some reason i am just thinking that the muffler might be clogged up. it has been on scine 99 and with the chip i am thinking she might be full of soot. plus i would like to hear it a bit more outside the cab but no inside. it is already hard enough to talk in there as it is. to be honest i dont really know why i want to do it. just a change i guess
Old Feb 27, 2006 | 06:09 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
i just did it the other day, and im not going back to a muffler. with the muffler, i had a hellish drone around 1750-2250 rpm, and now with a straight pipe, i would say 80-90% of it is GONE! contrary to JTharvey.. i do love it, the turbo whistles ALOT better, the engine has a throatier sound when you get above 1750 RPM from inside the cab, but it is no means intrusive. just very nice sounding. it isnt any louder inside i dont think. i tend to drive around town with my back windows down more though. you also lose 25-30 pounds in a muffler.
Old Feb 27, 2006 | 08:16 AM
BuickTurbo's Avatar
BuickTurbo
4" pipes here too, no drone at all.
YANK IT OUT!!
Old Feb 27, 2006 | 09:01 AM
Wieckster's Avatar
Wieckster
What about a 5" system should you run a muffler or straight pipe I am looking at ordering 5" system
Old Feb 27, 2006 | 09:46 AM
BuickTurbo's Avatar
BuickTurbo
As far as I know there are no mufflers with 5" inlet/outlet. I could be wrong. So look for a restriction there....if you wanna be picky.
Old Feb 27, 2006 | 09:47 AM
jtharvey's Avatar
jtharvey
I guess the best way is to just try it. Get some straight pipe from a big rig shop, some couplers & clamps, and put it on. I got away doing it cheap, and I believe strokin did too -- like under $40.
