What supplies needed for CCV mod?
Old Feb 26, 2006 | 10:16 PM
TXsnyper's Avatar
TXsnyper
Question What supplies needed for CCV mod?
I plan on doing the ccv mod soon, but I want to have all of my supplies ready to go. I don't want to get the truck torn apart then see I need more stuff, then have to drive to home depot to get more supplies.
I have seen the "kits" on ebay. However I feel that I can save a good chunk of change just buying the right size hose and fittings from home depot.
I basically need to know what size hose I need to use ID and OD, any other fittings needed, other than the ones needed to conect into exhaust.
Thanks for the help.
Old Feb 26, 2006 | 10:31 PM
the1mg's Avatar
the1mg
A GOOD mechanic
I think you know who this is
Old Feb 26, 2006 | 11:58 PM
hink10's Avatar
hink10
I just did mine today. I used 18 ft of 3/4 heater hose. I didn't reverse the doghouse. I used a 90 degree 3/4 pcv elbow attached to the existing 90 hose. That put the hose going to the back of the engine compartment, then over the master cylinder down to the frame and ended back by the tail pipe. If you wanted to flip the doghouse, forget the 90 degree pcv elbow and get a 3/4 coupler. I used 3 3/4 clamps to secure the hose. I removed the part of the intake that the ccv vented into (forget the name) and replaced with about 3" of 4" exhaust pipe. You could just cap the hole and leave the piece in place. Oh yeah, a few wire ties to secure the hose to frame etc.. Very easy and few parts. There are a few pics in my gallery. Hope this helps.
Old Feb 27, 2006 | 09:26 AM
Wieckster's Avatar
Wieckster
What do you gain by doing the ccv mod It sounds like a inexpensive mod any help would be great
Old Feb 27, 2006 | 11:51 AM
hink10's Avatar
hink10
The ccv mod prevents the oil from going through the turbo and intercooler and you will also get a little better air flow.
Old Feb 27, 2006 | 11:59 AM
TXsnyper's Avatar
TXsnyper
It seems like venting hot engine oily air into the "cold" air intake can't be all that good for things.
Do ya'll recomend using 4" exhaust pipe or just plugging the vent inlet into the air intake?
Old Feb 27, 2006 | 12:01 PM
hink10's Avatar
hink10
You will get better flow with exhaust pipe.
Old Feb 27, 2006 | 02:17 PM
SpringerPop's Avatar
SpringerPop
3-1/2 inches of it, to be exact!
Pop
