rear diff question
Old Feb 25, 2006 | 11:44 PM
77redford's Avatar
77redford
Question rear diff question
Bought ole red 5 years ago for $700, she's a 77 f-150, 400, c-6, full time 4 wheel drive, mechanicly when i bought her she was perfect, body was all rusted out but fixed her. Been an every day driver since. Question is rear end has started to growl ( checked oil and replaced u joints) the pinion comes out of the front of the diff, I'm wondering what kind of rear end is in it (theres no diff cover). I love ole red so she is parked until the weather smartens up and I can work on her. Any help would gratefully be appreciated.
Old Feb 25, 2006 | 11:46 PM
ford390gashog's Avatar
ford390gashog
that would be a ford 9''.
Old Feb 26, 2006 | 12:07 AM
77redford's Avatar
77redford
thanks gashog
Old Feb 26, 2006 | 12:41 AM
MBBFord's Avatar
MBBFord
Just wondering, does it have a metal tag on the bolt circle of the axle? If so, I'd be curious to know if it has a 3.00 gearing or 3.50 gearing, and also if it has a limited slip. If it has the tag on the bolt circle, could you post the numbers.
I also have a full time 4wd and it has 3.50 gears, but was told some came with 3.00 gears, and I would really like to know more about that.
Old Feb 26, 2006 | 06:49 AM
User 71024's Avatar
User 71024
You do know you can buy pretty much any gear set you want for a 9" don't you? And even if you can't do it yourself, they are the cheapest to have replaced because you can hand them the chuck cutting the labor and agrivation cost.
Old Feb 26, 2006 | 11:54 AM
MBBFord's Avatar
MBBFord
The reason I posted that didn't have anything to do with wanting to switch gear sets. I thought all 1/2 ton 73-79s had 3.50 gears, but everynow and then you might find a full time 4wd w/3.00 gears, It was just a curious and what to know(if there are such things out there).
I plan on going to 4.30 or 4.56, haven't decided yet.
Old Feb 26, 2006 | 12:06 PM
77redford's Avatar
77redford
there is no metal tag on the diff
Old Feb 26, 2006 | 12:09 PM
MBBFord's Avatar
MBBFord
How about on the front diff(metal tag on the bolt circle of the cover), it should have the same gears in it, but the front won't have a limited slip.
Thanks for looking though.
Old Feb 26, 2006 | 12:10 PM
Mil1ion's Avatar
Mil1ion
What is the code for the axle on the rating plate ?
This will tell you what originally came on that truck.
Noting the RPM's at a certain speed can be an indication of what gears are in it.
