View Poll Results: What is this short block worth?
$1400
16
59.26%
$1500
7.41%
$1600
18.52%
$1700
3.70%
$1800
3.70%
$1900
3.70%
$2000
3.70%
Voters: 27. You may not vote on this poll
400 Short Block
Old Feb 25, 2006 | 08:27 PM
TMI's Avatar
TMI
400 Short Block
I would like to get some ideas for what the going rate would be for a 400 shortblock. We have built 1 so far and I am tring to decide what the market is and the price range. Also how much we should put into it. Here's what we have in ours, over kill??
Balanced roatating assy. with stock parts.
Rods reconditioned with ARP bolts.
Badger flat top piston
moly rings
includes new balancer and flexplate
Block has been Baked, blasted and maged
align honed
resurfaced
bored
new cam bearings
Brass expansion plugs
Entire assembly has been run on our Simtest for prelube and inspection purposes.
What your idea??
Old Feb 25, 2006 | 08:47 PM
termyt00's Avatar
termyt00
sounds good! for what you list i'd say 800$ is a realistic price. stock block with a oil restricter kit, stock crank, H-beam rods, Forged pistons, set of aftermarket CJ heads...and a good cam...would go for about 2800$
Since i have a 400 with Cj heads, cam, torker intake...(stock internals) and restricter kit.
Old Feb 26, 2006 | 09:39 AM
bmc69's Avatar
bmc69
CJ heads?...what are you referring to there?
Tim,
I voted for the $1600 range..since that is roughly what it would go out of our shop for with similar specs IF we sold them as short blocks..which we don't; we only sell completed engines, 'tin and all', so I had to guess on subtracting a few things.
-Bill
Old Feb 26, 2006 | 10:31 AM
termyt00's Avatar
termyt00
We are talking about a 400M right? the engine that was put in just about every Ford car and truck in the 70's and early 80's, possibly a couple of million produced!
CJ Heads are Cobra Jet heads off a 351c. I believe it is Edlebrock that has a updated Boss 302 style head that they are now reproducing. aluminium of course. it might be a Robert Yates spinn-off.
Old Feb 26, 2006 | 10:56 AM
bmc69's Avatar
bmc69
400..no 'M'..and yes, that was what the thread is about.
We have been using the 302C Aussie closed-chamber 2V heads for many years and still do..the new Edelbrock heads are very similar the Aussie closed-chamber heads. There is a good chance we will be using a set of those for a build that is just starting..a 434 stroker with MPFI..but not certain yet. If the customer does go that way, it wil be the first 400 we build with aluminum rather than iron heads.
Old Feb 26, 2006 | 06:40 PM
termyt00's Avatar
termyt00
Glad to see some one is giving the 400 the att'n it deserves! but most people are going with the windsor strokers. my 400 does relatively well with the 4v quench heads. ya i forgot the CJ's were open chamber. I can pull a few stumps and stangs too.
Old Feb 27, 2006 | 12:17 AM
ron_29_1973's Avatar
ron_29_1973
the 6.6 liter 400 eng in truck's had to be ordered it was not the standard eng they are more 351m's out there than 400's.
Old Feb 27, 2006 | 12:41 AM
termyt00's Avatar
termyt00
remember the 400 came in LTDz / Torino's /Merc's/ LTD II way before they started in the trucks, the 400 started production in the early 70's (i think it was in 72) before the 351m! the 400 production ended in 82/83, the 351m only ran production from; i think 75 to 79, and a few may have lingered to 80. the 351m was just a bad idea from the get go.
Old Feb 27, 2006 | 12:58 AM
ford390gashog's Avatar
ford390gashog
351m ran from 77-82 in trucks.
Old Feb 27, 2006 | 01:42 AM
Brian S's Avatar
Brian S
Based on the 383C dyno that made 435TQ @ 3000 with ported 4V heads, I don't see why an engine with an additional 25ci couldn't pass 450 or more likely even 460 at the same rpm. The 383C made peak TQ of 463 and also maintained well over 420TQ to beyond 6000 rpm, all while running a stock cast iron 4V intake.
4V heads get a raw deal everytime the torque subject comes up. Usually the blame should fall on a poor intake and cam selection.
Old Feb 27, 2006 | 07:23 AM
bmc69's Avatar
bmc69
We aren't 'anti-4V head' for any irrational reason..it's just that for the engines we build that do not see over 4000 RPM, the port size/runner volumes of the 2V heads is a much better match. Not to mention that the intake selection from which to choose from is better too. We even use the much-maligned SP2P intakes on some builds...they serve the purpose for whihc they were intended, which was to increase the low-RPM runner velocities...with 2V heads.
We do build high-RPM racing engines too..for MX/TT racers and mud-boggers. But to date, none of those have been 400s...sooner or later we'll be building a 400 with 4V heads, I'm sure.
Old Feb 27, 2006 | 12:23 PM
termyt00's Avatar
termyt00
i have to admit my 400 likes to pull from 1500 past 6000 with the 4v heads. i cant do that though, cause the thing might fly apart...
Old Feb 27, 2006 | 05:58 PM
Modified's Avatar
Modified
tim,
lets up the anty. Make a poll for a 434 stroker shortblock. I feel most would have more intrest in that. The word stock is a turn off to most truck guys!
just a thought!
Old Feb 27, 2006 | 11:22 PM
Torque1st's Avatar
Torque1st
Posting Legend
The 400 started production in MY 1971 which meant it was produced starting in 1970 as a 1971 model. First year production power and torque was outstanding.
Old Feb 27, 2006 | 11:47 PM
termyt00's Avatar
termyt00
according to sources 71 was the official first year for the 400 [335 series],
69/70 was the last year the FE was ever put in a car, the 400 was a replacement for the FE. it bacame known as a 400m after 75 along with its bas_tard cousin the 351M.
