Heads.............interchangable?
Old Feb 25, 2001 | 08:13 PM
HiMe's Avatar
HiMe
Old Apr 3, 2001 | 06:59 PM
blaxuede's Avatar
blaxuede
I was just wondering if heads are interchangable. I don't see why they shouldn't be , just a question.
Old Apr 3, 2001 | 07:25 PM
Nathan's Avatar
Nathan
Yep
Nathan
Old Apr 3, 2001 | 09:04 PM
sparky's Avatar
sparky
If you mean between a 6 and 8 cylinder or an FE and a 302 or a 460 or a I6 not likely without alot of machine work. LOL
Sparky
>, just a question.
Old Apr 3, 2001 | 11:07 PM
Franklin2's Avatar
Franklin2
Watch out for the smog port on the end of the head if it is a 302. This doesn't matter if you are going to plug it though.
Old Apr 4, 2001 | 06:35 AM
72f100's Avatar
72f100
Some are some aren't. 302 and 351W; yep 302 and 390; nope 302 and 351C; kinda. The heads on engines from the same family are interchangeable most of the time, like 289,302 &351W are interchangeable but the cleaveland is a different engine family and are not easily swapped. It can be done w/ some machine work but it aint cheap.
"Like a Rock"; on the sides of roads everywhere.
Old Apr 4, 2001 | 06:43 AM
FE427TP's Avatar
FE427TP
I believe he means from the left hand side of the engine to the right hand side and the answer would be yes they can be swapped from left to right in most cases, but make sure for your application beforehand
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
