1998 expedition
Old Feb 25, 2006 | 11:47 AM
Johnson9800's Avatar
Johnson9800
1998 expedition
OD switch does nothing when pressed well experienced mechanic where do I need to look first
Old Feb 25, 2006 | 05:36 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Feb 25, 2006 | 06:03 PM
FTE Herman's Avatar
FTE Herman
Welcome Johnson9800!
I take it you are expecting the RPM's to rise when traveling at highway speed (why you said 'nothing happens').
Are you driving at a high enough speed that the transmission has entered an OD state?
(I know silly questions but I have to ask.)
My only guess would be faulty wiring, perhaps some folks who are more literate with transmission operation can jump in here.
Old Feb 25, 2006 | 07:18 PM
lynnr's Avatar
lynnr
Nothing at all? No O/D light on the shifter?
Old Feb 26, 2006 | 08:27 AM
projectSHO89's Avatar
projectSHO89
Probably faulty wiring leading from the switch to the column.
Pull the shroud and check the switch continuity.
Also, check F29.
Steve
Old Feb 26, 2006 | 10:51 AM
Johnson9800
I can be running 75 with no load in overdrive and when I press the button nothing happens. No down shifting out of overdrive, no light comes on, nothing. Just bought the expedition a month ago. Like to get some input before tracing for the problem for hours.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
