Tim Meyers 434 stroker kit.
Old Feb 25, 2006 | 09:43 AM
Modified's Avatar
Modified
Could someone gine me a link to this site or give me some info I am planning a rebuild on my 78 400M and I am amazed at the potential of these old smog motors. A buddy of mine has a dyno software and I put in the data for the planned builb using 185cc 3V CHI heads, dual plane intake, stock cam @ 10.5 to 1 compression and beleive it or not 550lbs. of torque @ 2000 rpms holding to 600lbs @ 5000 rpms. and 475 hp at 4800 rpms. At least this is what the software projects. I 'd sure like to break 500 Hp and that stroker kit may be just the thing to get me there without having to go over 5000 rpms.
Thanks
Old Feb 25, 2006 | 11:05 AM
ivanribic's Avatar
ivanribic
I couldn't tell you the first thing about them or what mods are necessary to make it work but here's a couple links for parts:
http://www.tmeyerinc.com/cart434kit.htm
http://www.strokerkits.com/351___400m.htm
You might also ask in the 335 forum here that deals specifically with those engines as there's some experts in there that will have good info for you:
https://www.ford-trucks.com/forums/f...splay.php?f=54
Old Feb 25, 2006 | 01:15 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have on FTE. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
Old Feb 25, 2006 | 06:39 PM
TMI's Avatar
TMI
If you keep watch, we will have a 434 (400 stroker, also nic named "Super Cleveland" by the owner) on the dyno in just a few weeks.
Old Feb 25, 2006 | 08:23 PM
Modified's Avatar
Modified
Thanks
Tim,
Thanks
Old Feb 25, 2006 | 08:54 PM
Modified's Avatar
Modified
Tim,
Thanks for the respone. What is your opinion of the chi 3V 185cc heads. I really want to build my torque an Hp at low rpms. I am setting a plan to build my engine and right now the CHI 3v's seem to be the way to go. Any advise?
Old Feb 25, 2006 | 10:07 PM
Torque1st's Avatar
Torque1st
Posting Legend
Tim has run some tests that are posted in this forum. Check out his past posts.
Old Feb 27, 2006 | 12:46 PM
apachetech's Avatar
apachetech
I am building my 434 motor using Tim's kit. I have the blocked bored .030 over, 4 bolt main caps installed, pistons dished for a 10:1 CR; just got my head stud kit on Friday and will be dropping it off at the machine shop today. I plan on using the CHI 2V heads because they flow better in the low end rather than the upper end like the 3V heads do. I am putting this motor into my 77 F250 4x4 and I will be posting more updates as I make progress!!
scottmorgan1309
34
Mar 9, 2017 05:31 PM
Brandy4ever
13
Nov 27, 2016 07:12 PM
FOEngineer
Jun 4, 2015 11:00 AM
jerg_064
24
May 28, 2009 04:19 PM
The67Beast
Mar 14, 2007 12:15 PM
