Pulled the codes
Old Feb 25, 2006 | 04:46 PM
Numpty's Avatar
Numpty
Pulled the codes
Well today i bought a diagnostic computer for my 92 f150 4.9l and pulled the codes from it. I got:
118 Engine coolant temperature above maximum voltage, assuming i need a new coolant sensor.
Now the ones i don't know how to fix!!
327 EGR valve position circuit below minimum voltage
332 Insufficient EGR flow detected
I'm assuming that i have a problem with my egr valve, how do i go about fixing this and how much am i looking to spend?
Thanks for you help, i was quite skeptical about buying this, but the one i got only cost $50can and actually turned out to be pretty useful. You can hear it working through all of the sensors as it does the tests kinda cool. I would recommend buy one and giving your truck a test
