intermittent wiper control box
Old Feb 25, 2006 | 07:31 AM
Sicko's Avatar
Sicko
Since I purched my used 83' f250 I would have to skillfully time the wipers to turn them off in the right position. Well I went thru the wiring and found that the I have an intermittent wiper control box on my dash was not hooked up. It has five wires "if im not mistaken" red, green, blue, black and white The thing is I can only find places for the black, white, and blue. hooking these wires up I fixed the problem but where do the others go? Please help.
Thanks,
PJ
Old Feb 25, 2006 | 07:38 PM
srercrcr's Avatar
srercrcr
Something is strange.
My 83 wiring diagram shows:
Black/light green to ignition switch via a connector.
Black/white to washer pump.
Red to the INTERVAL GOVERNOR.
Black to ground.
Black/pink to INTERVAL GOVERNOR.
Black to INTERVAL GOVERNOR.
Dark brown/orange to wiper motor.
Old Feb 26, 2006 | 08:01 AM
Sicko's Avatar
Sicko
Are you talking about the wiper switch itself, or the cheap little black box with one ****?? Also what book do you have? I have a chiltons.
Old Feb 26, 2006 | 06:54 PM
srercrcr's Avatar
srercrcr
The book is an electrical and vacuum troubleshooting manual I bought in 83 when I bought the truck.
It has thorough wiring diagrams.
The wires are coming off the intermittent wiper control box just as you mentioned.
I don't know why there's a discrepancy. I can just tell you what it says. Sorry.
Old Feb 26, 2006 | 08:07 PM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
If someone eliminated the intermittant wiper system by unplugging the "box" and putting a non-intermittant switch in your truck it will never work right. The intermittant system Ford used on these vehicles is a dual funtion switch with a governor plugged into the standard wiper system. The intermittant is activated by turning the switch **** to the left (counterclockwise) the cycle speed is controlled by a resistor in the switch. The low and high is activated by turning the switch **** right (clockwise). Pushing in on the **** activates the washer pump. It is fairly easy to add intermittant wipers by simply replacing the switch and adding the governor. If your wipers won't stop properly, than the park switch in the motor may be bad. The wiper harness plugs into the governor and the other end of the governor harness goes to the switch.
Old Feb 27, 2006 | 11:48 AM
Rosie's Avatar
Rosie
I too replaced my windshield wiper switch with an intermittant switch over the weekend. It doesn't function correctly. Being my truck didn't come standard with this switch, I must assume I need to add the governor as well as the intermittant switch for the switch to work correctly.
Can someone confirm this? Thanks. I do have the Ford truck manuals. They are very helpful and easy to understand.
Old Feb 27, 2006 | 12:01 PM
pknute's Avatar
pknute
You need the complete wiper switch and control box that is harnessed together with a connector on the end that connects to the original connector your non-interval wiper switch was attached to. The complete units are for sale on eBay all the time.
Old Feb 27, 2006 | 07:47 PM
srercrcr's Avatar
srercrcr
They both use the same wiper motor???
My old Pontiac uses a diff motor for the delay setup.
Old Feb 27, 2006 | 08:19 PM
pknute's Avatar
pknute
This is 80-86 Ford Truck Country and the wipers are driven by one motor. The controller is simply an electronic device to determine when power is fed to the single motor and when it is not. Simple device really...
Old Mar 1, 2006 | 06:49 AM
Sicko's Avatar
Sicko
Black to ground.
I figured out what you meant I looked at my book at the house and names for the two switches are similar.. Sorry I took to long to reply but work has had me busy.
Thanks,
Pj
Old Mar 1, 2006 | 07:15 PM
Rosie's Avatar
Rosie
I got the governor for the intermitten wiper switch today from my local Ford dealer. The governor is a black box with two connectors. One connector is red. The red connector goes on the switch. The other connector is black. The black connector goes on the harness under the dash. The only tricky thing is to find a spot under the dash to mount the black box. If you've done it right the intermitten is to the left and normal operation is to the right as you turn the switch. Push on the switch and your squirter should make your windshield wet. Hope this helps.
Ted's77
13
Aug 16, 2012 04:38 PM
Blue and White
Jan 1, 2012 05:34 PM
SCD
Mar 11, 2010 07:18 PM
Diezel2010
Feb 16, 2009 11:56 PM
Walston
Feb 16, 2008 08:08 AM
