Wiper wiring conversion help needed.
Old Feb 10, 2008 | 02:33 PM
Walston's Avatar
Walston
I am in process of installing a Ranger wiper motor on our 1960. We have the new motor in place following krautwolf's gallery.
I have the intermittent switch from an early 80's F150.
OK here is the deal. 4 wires from the motor, black, red, white and blue.
6 wires on the plug coming from the 80's vintage intermittent switch, see photo below. The red plug goes in the switch I already installed in the dash. The black plug will be removed and wired direct since I don't have the mating plug.
There are 6 wires on the black plug.
1) One black going to the red plug thus to the switch- I assume this is where I should hook up the power supply.
2) Another black going to the "box" - I assume this goes to the black wire from the motor.
3) Red going to the "box" - I assume this goes to the red motor wire
4) White going to the "box" - I assume this wire goes to the white motor wire
5) Blue going to the red plug thus to the switch - I assume this goes to the blue motor wire
6) Black with a white tracer going to the red plug thus to the switch - I assume this is for a washer which I don't have.
I would really like someone to double check my logic, I don't want to hurt my new wiper motor.
Thanks for the help.
Old Feb 10, 2008 | 03:12 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Your logic seems correct, but I'd put a 5A circuit breaker in each line to the motor until you verify a "no smoke" configuration!
Old Feb 10, 2008 | 05:29 PM
sdetweil's Avatar
sdetweil
I found this picture of the wiring diagram
Sam
Old Feb 10, 2008 | 05:51 PM
Walston's Avatar
Walston
Perfect! Thank you very much!
Old Feb 16, 2008 | 08:08 AM
Walston's Avatar
Walston
1) One black going to the red plug thus to the switch- hook up the power supply.
2) Another black going to the "box" - hook to the black wire from the motor.
3) Red going to the "box" - hook to the red motor wire
4) White going to the "box" - hook to the white motor wire
5) Blue going to the red plug thus to the switch - hook to the blue motor wire
6) Black with a white tracer going to the red plug thus to the switch - tis is for a washer if you have one.
I just wanted to close the loop on this for future reference. As shown in the wiring diagram and from my actual installation. The way I described the wiring in the above quote is correct. There is many pictures and details in my gallery.
81-F-150-Explorer
74
Aug 10, 2015 02:23 PM
D & D
Sep 1, 2014 01:11 AM
SocialDistortionFan
Jul 24, 2013 08:15 PM
travelingman55
Nov 4, 2012 10:36 AM
Ted's77
13
Aug 16, 2012 04:38 PM
