This is the only info I could find for it.Everywhere else I searched said it was an invalid number.2ftjw35cxfc816640
Description.....Position Raw......Data Decoded Data
Region: ...........1........ 2 .........North America
Country:..........1-2.......2F.......Canada
Manufacturer:...2-3.......FT.......Ford
Model Specific:..4........ J......... 9,001 to 10,000 pounds
......................5-8.......w35c...Unknown
Check Digit:........9....... X.........Invalid
Year:................10.......F..........1985
Assembly Plant:...11......C...........Ontario, Can
Serial Number:....12-17...............816640
trying to find out what engine and tranny came stock havent had good enough weather of a garage to get up under the truck and look for tags or casting numbers yet
The 8th position is the engine type code.
The tranny and axle code is on the lower part of the data plate on the door jamb.
Get them and we'll check er out.
Tranny door code K = Auto. C-6
Conventional:
Axle codes:
F-150/250/350 non Limited Slip:
Code...........Man...Size...GVW..Gear Ratio
45.............Ford............7400........4.10
Could the C be a G? If so, that would make the engine a 5.8L or 351 with a 2bbl carb. My 86 is 2FTJW35L0GCBxxxxx for Canadian built Ford Truck J being the same 9001 to 10000 GVW W35 is a crew cab L is the 7.5L (460) engine 0 is the check didgit G is the year, 1986, C is Ontario Canada and Bxxxxx is the consecutive unit number. Hope this clears up the rest.
