Looking for new shocks
Old May 20, 2007 | 10:04 PM
  #31
bobbylh's Avatar
bobbylh
Well I got the rear shocks changed, and it was fairly simple.
When trying to change the fronts, I loosened the shock nut and three nuts around it, jacked up the truck, removed tire, but there still seemed to be a lot of pressure on the spring. I went to autozone and got the spring compressor, and tried that, but still seemed like a lot of pressure. I had to turn both of them a 1/4 turn at a time. There isn't much room to use these things. I couldn't budge the spring at all. My question is what will happen to the spindle when I unbolt the upper control arm? I guess I'm worried that it will fold or slam down and mess up my brake lines, or my arms. Do I need to support it somehow?
I put it back together, and the rear shocks did help the bounce, but I would like to try them fronts next weekend.
Thanks
Old May 20, 2007 | 10:49 PM
  #32
73mach1's Avatar
73mach1
you do not have to undo the control arm if you do you will need to have a front alignment done if your going to do that just pay some place to replace them for you. that big o spring is under a lot of pressure and can be dangerous it can come out and break bones
Old May 21, 2007 | 12:24 AM
  #33
MeanGene1's Avatar
MeanGene1
Thanks
I used the spring compressor method, but from what I have been able to gather. You have your truck supported with the front wheel off, you also have to have a jack under the lower control arm with some pressure on it. You need to remove the upper control arm nut so that the lower control arm can move down enough for the spring to become uncompressed and removable, this means that the center nut from the shock has been removed. I don't think anything can go wrong if you ensure that the spring has lost all compression while lowering the jack.
That is using the "on the truck" method. If you have a spring compressor. Make absolutely sure that that center nut is on and tight and remove the entire shock assembly with spring, you will need to seperate the tie-rod end from the steering knuckle in order to have enough room to remove the shock assembley. Then use the spring compressor on the bench and follow the instructions that comes with the shocks.
Old May 21, 2007 | 07:00 AM
  #34
mbogosia's Avatar
mbogosia
BWEP,
Did you notice a nice improvement with your Add A Leaf? I might be the exception, but after I had an Add A Leaf installed my handling has improved tremendously. I can take corners like I am on rails and over bumps the truck skips much less.
Old May 21, 2007 | 08:48 AM
  #35
bwep's Avatar
bwep
add-a-leaf and shocks
I also thought my ride and handling improved with the add-a-leaf. The skyjacker add-a-leaf was advertised as 1-1/2 ride increase but turns out to be more like 2". It might be in my head now but I think the trucks handling over bumps now has declined making me think that the shocks are on there way out. Maybe with the leaf and 2" auto spring the stock shocks might not be long enough for the added increase in suspension travel. Seems most noticeable on hiway. Well the trucks at 35,000 looks like I’m going to spend some money, brakes and shocks are on my list followed by my tire upgrade. So far all my upgrades have made the truck more fun to drive and I’m sure these will improve fun factor also. BWEP
Old May 21, 2007 | 02:39 PM
  #36
tdister's Avatar
tdister
yeah, look into something a little heavier duty for the shock. Your stiffer spring set-up is going to need a heavier shock to keep everything tamed.
It does depend on what it's doing though, as to whether the shocks will smooth the ride. Is it just stiffer or are you getting excessive/more bounce?
Old May 21, 2007 | 04:46 PM
  #37
bwep's Avatar
bwep
I would describe it more as a side to side motion at hi-way speeds. Truck did not seem to stiffen at all with the add-a-leaf. For six months rode better than stock now it’s seems to be a little off. I will go with a heaver shock when I replace them. Just still on the fence if I’m going to spend the extra on the bilstiens or go with the ranchos.
Old May 21, 2007 | 05:45 PM
  #38
bobbylh's Avatar
bobbylh
Thanks Guys. Meangene1 I think you had the answer I was looking for.
juddspaintballs
Mar 19, 2015 07:24 AM
evilwayz7
2004 - 2008 F150
Mar 17, 2011 03:12 PM
mdwilli
Apr 21, 2009 10:25 PM
GHog
Offroad & 4x4
17
Aug 14, 2005 10:13 PM
GHog
Aug 7, 2005 12:51 PM
