won't turn over
Old Mar 4, 2006 | 03:08 PM
Bdox's Avatar
Bdox
I expect that the new solenoid is going to fix it if the battery is good.
There can be a high resistance in an old cable due to corrosion build up under the insulation.
Put a volt meter across the battery and engage the starter for ten seconds. If the voltage drops to ten volts or less, change the battery.
Old Mar 5, 2006 | 01:11 PM
4.9inline6's Avatar
4.9inline6
we figured it out. i had overlooked my grounds and had not grounded the engine to the frame, breaking the ground loop. i went ahead and replaced all the pos and neg wires anyway and bought a new solenoid, even though the other was not yet bad. i figured, 12 bucks for a lifetime warranty is a good deal. i would rather replace it now than get stranded. thanks everyone for all your help. i haven't actually started it yet but plan to go crank it over here in about an hour or so...first time running in 4 years!! im excited.
chris
Old Mar 5, 2006 | 01:21 PM
Bdox's Avatar
Bdox
Good work! Post your results.
Old Mar 6, 2006 | 08:05 AM
4.9inline6's Avatar
4.9inline6
its alive!! started up after like two cranks. good to finally hear it go.
chris
AtlM5
Dec 13, 2015 07:57 PM
Uncle Paul
May 22, 2014 09:33 AM
Wooticus
Jun 16, 2013 11:57 PM
keyul
May 21, 2011 02:49 PM
rookietech
Sep 15, 2004 11:04 AM
