a little direction
Old Feb 23, 2006 | 07:33 PM
amish77's Avatar
amish77
Red face a little direction
well I've known for some time that the rear axle in the 77 is going out, and as it strted to bind in reverse the other day, I think that I better get on it. Here's my question. I"m planning on making this thing more towing/hauling capable, so should I stick with the old dana 44 and build it up, or go with a ford 9'' instead? Any help would be appreciated.
Old Feb 23, 2006 | 10:04 PM
thesprocket26's Avatar
thesprocket26
Full floater Dana 60 at least. Very strong. You can easily get parts and upgrades for a D60 too.
Old Feb 24, 2006 | 08:39 AM
amish77's Avatar
amish77
I thought you could go full floater with a 9". Either way the 60 makes sense. Would the 60 hang from the current suspension? I'd like to do this job a little at a time. 77 f100, 3leafs in the rear.
Old Feb 24, 2006 | 11:21 AM
andym's Avatar
andym
I think thesprocket misunderstood your post. You don't want a Dana 60. For one, you'd have to carry two spares.
The rear Dana 44 in a Ford is a rare bird. The 9" is a stronger unit. I'd swap one of those in and get it set up with the gears that you want. If you're doing a fair bit of hauling/towing, I'd go with 3.73's or 4.11's.
One of the perks of going with a 9" is that you can easily swap third members out. You keep one set up with 4.11 gears and another with 3.00 gears. That way you can pick the third member you want for the job you want it to do - hauling or gas sipping.
Old Feb 24, 2006 | 12:24 PM
amish77's Avatar
amish77
I thought that might be the case. I'm not all about dual spares, though I do have the room under the bed. any way that I could swap in some axle tubes with my bolt pattern? But now we're probably getting into more work than I can pull off in a week.
The 77 f100 was the only one to get the 44 to my knowledge. Anyway, can I go full floating with a 9" and if so how hard is it to do? I like the expense factor of the 9'' better. I've heard that the towing/hauling of a full floating axle is far superior to those that aren't. Thanks for the posts thus far guys, I'm enjoying the info.
Old Feb 24, 2006 | 04:55 PM
thesprocket26
What is a full floating 9"? What rigs do they come in? Full floater D60's aren't always dualies.
Old Feb 24, 2006 | 05:14 PM
amish77's Avatar
amish77
I've heard that there's a conversion for a ford 9" that makes it a full floating axle.
This is to my knowledge where the axle tube (outer casing) holds the external forces and the internal axle has only the engine forces to deal with. Most regular axles have both forces on the internal axle shafts. I could esaily be wrong on this, as I've kinda pieced it together from stuff people have told me.
Old Feb 24, 2006 | 08:13 PM
surewhynot's Avatar
surewhynot
I think when he said dual spares he was meaning having an 8 lug rear pattern and a five lug front
Old Feb 24, 2006 | 10:25 PM
thesprocket26
gotcha
Im a little slow today
Old Feb 25, 2006 | 03:40 PM
amish77's Avatar
amish77
yeah 8 logs might looka a little weird.
77whiteranger
Dec 6, 2008 04:13 PM
77f2504by4
Nov 7, 2005 02:36 PM
Ford4me302
Mar 17, 2005 11:59 AM
frdhighboy77
Montana Chapter
Apr 7, 2004 08:54 AM
zsir
Jan 7, 2003 11:45 AM
