1978 - 1996 Big Bronco
'88 bronco, 302 ignition timing numbers
Old Feb 23, 2006 | 04:25 PM
bmarkey's Avatar
bmarkey
Arrow '88 bronco, 302 ignition timing numbers
My Bronco's timing decal is missing from under the hood and the Haynes manual says to refer to the decal. Does anyone have the info from their Bronco to share? I had to remove the distributor to replace the ICM, and I want to make sure the timing is set correctly.
The engine is the 5.0L and is not modified.
Thanks,
BMarkey
Old Feb 23, 2006 | 06:00 PM
jem270's Avatar
jem270
unhood sticker
Is this what you need?
Old Feb 24, 2006 | 02:05 PM
bmarkey's Avatar
bmarkey
Yes indeed, thanks so much.
BMarkey
JackOHearts
Mar 19, 2020 08:40 AM
z31freakify
Sep 20, 2015 07:49 AM
ltlblutrk
May 12, 2015 04:30 PM
Rusty_S
15
Feb 8, 2015 06:17 PM
nitemandick
Nite, Nascar & Other Limited Edition Ford Trucks
Dec 5, 2012 01:50 PM
